If you have an $N$ degrees of freedom system what does this mean?
What is the difference between a 1 and a 2 degrees of freedom system?
- 220,844
For example an object can vibrate in one dimension only (e.g $x$, thus $1$ degree of freedom).
Or an object can vibrate in 2 dimensions (e.g $x$ and $y$, $2$ degrees of freedom)
Furthermore an object can vibrate in a rotational sense, a further degree of freedom (in this case an angle lets say $\phi$, in a classical sense and not a quantum-mechanic sense).
References:
- 5,302
One degree of freedom is a straight line between 2 points. It has no width and no plane in which to vibrate. A line between 2 points involves distance which implies time. Assuming that time is a dimension a straight line requires time and a 2 dimensional plane in which to vibrate. Hence, three dimensions are required to allow the simplest of vibrations. Four dimensions allow a simple vibration to rotate, and so on up. String theory allows more complex wave functions in higher dimensions, each requiring their own manifolds (higher dimensional spaces).
