I need to verify a solution to Einsteins vacuum field equations. I have the solution as follows $$ds^2=a\,dt^2+b\,dr^2+\cdots$$
Is the following the right approach? Einsteins equation reduces to $R_{ab}=0$, which can be expressed in terms of Christoffel symbols which can be defined by the metric.
How does one obtain the metric from the line-element?
Once I have the metric, do I just plug it into $R_{ab}=0$ and check? This seems very tedious, am I on the right track?
Added:
If I change the coordinates, and show that this new metric satisfies Einsteins vacuum Equation, would it follow that the original coordiantes and metric does so as well?
The line element in terms of the metric $g_{\mu\nu}$ is given by,
$$ds^2=g_{\mu\nu}dx^\mu dx^\nu$$
As you haven't provided the entire line element in the post, I can only say $g_{tt} =a$ and $g_{rr}=b$. If it is the case that $a,b$ are constants, as well as any other components of the metric, then trivially $R_{\mu\nu}=R=0$.
Otherwise, you pretty much have to compute the Ricci tensor $R_{ab}$ directly. However, there is a much faster method than using Christoffel symbols which is called the Cartan formalism. I have summarised it in other answers, see:
Very quickly: you choose an orthonormal basis $e^a_\mu$ such that $\eta_{ab}e^a_\mu e^b_\nu = g_{\mu\nu}$, and you can read off connection components $\omega^a_b$ from $de^a + \omega^a_b \wedge e^b = 0$. The curvature 2-form is $R=d\omega^a_b + \omega^a_c \wedge \omega^c_b$.
In addition, I recommend Ruth Gregory's lecture at perimeterscholars.org which provide an introduction to the method, and preliminaries introducing differential forms if you are not familiar with them.
If you are given a metric $g_{\mu\nu}$, and change coordinates, you are still describing the same manifold; general relativity is invariant under diffeomorphisms.
JamalS
  • 19,600
