I found a nice answer to a problem that was bothering me for quite a while in a lecture script (unfortunately in german). The first step of the answer, is what remains unclear to me. The script states that the transformation of a quantum field $\phi$ can be written in two different ways:
$$ 1) \qquad \phi \rightarrow e^{i\alpha_a T_a} \phi $$
with the generators of a SU(N) symmetry group $T_a$ and
$$ 2) \qquad \phi \rightarrow e^{i \alpha_a Q_a} \phi e^{-i \alpha_a Q_a}, $$
where $Q$ denotes the Noether charge. Considering infinitesimal transformations we have
$$ \alpha_a T_a \Phi = [\alpha_a Q_a,\Phi] $$
This can be used to show, that the two criteria for spontaneous symmetry breaking:
I $Q_a |0> \neq 0$
II $<0|\phi |0>\neq 0$
follow from each other.
I means the vacuum is not invariant under this symmetry, because $Q |0> \neq 0 \rightarrow e^{i Q} |0> \neq |0> $. And II means a scalar field, with a non-vanishing Vacuum-Expecation Value exists.
My problem is understanding, why there a two different transformation laws for $\phi$, one using the Noether charge, and one using the generators. I always thought that in QFT we identify those two with each other: $Q \leftrightarrow T$ (For a proof see for example this question: Connection between conserved charge and the generator of a symmetry)
jak
  • 10,431
I) It is difficult to comment without seeing the textbook, but one interpretation is that it is essentially just a matter of assigning appropriate representations as follows. Let $G$ be a Lie group with the corresponding Lie algebra $L$. Let $\exp: L\to G$ be the exponential map. Let $t_a\in L$ be a Lie algebra generator. Let $A$ be an algebra with a set $A^{\times}$ of invertible elements.
II) Let
$$r: G ~\to~ A^{\times}$$
be a Lie group homomorphism. The Lie group homomorphism induces a corresponding Lie algebra homomorphism
$$r:L~\to~ A,$$
which we also call $r$. Let
$$ Q_a~:=~r(t_a)~\in~ A.$$
III) Consider a Lie group/algebra representation
$$R:G~\to~ GL(A,\mathbb{C}), \qquad R:L~\to~ gl(A,\mathbb{C}),$$
defined as
$$R(g)\phi~:=~ r(g)\phi r(g)^{-1}, \quad g\in G, \quad \phi\in A,$$ $$R(t)\phi~:=~ [r(t),\phi], \quad t\in L, \quad \phi\in A,$$
respectively. Define
$$T_a ~:=~R(t_a)~=~[r(t_a), \cdot]~=~[Q_a, \cdot]~\in~gl(A,\mathbb{C}) .$$
