I have looked online to no avail. There is two competing answers and I am curious to know which one is right.
Someone asked me this question. If you are traveling at the speed of light can you see your reflection in a mirror in front of you?
My answer to the question is no, I would figure that in order for that to happen the light reflecting off you that would appear in the mirror must travel faster than the speed of light to actually reach the mirror (which we all know is impossible).
He says the answer is yes, that it is all relative to the current frame of reference.
Can anyone validate the correct answer with possible references?
John V.
  • 159
7 Answers7
13
This question cannot really be answered because you cannot travel at the speed of light. See Accelerating particles to speeds infinitesimally close to the speed of light?
If you were massless, you would always travel at the speed of light. However, in that case you would not perceive the passing of time. In relativity, the time that passes for an observer depends on the proper time. The proper time for a light-like trajectory is always zero, so photons themselves do not experience the passage of time.
If you travel very near to the speed of light - perhaps 99.9% light speed relative to Earth, you would still be able to view yourself normally in a mirror you carried with you. That is ensured by the principle of relativity, which states that all physical processes work the same way at any constant speed.
Your friend is correct that it depends on the reference frame (see previous answers). Both of these responses are correct, the only difference being that Mark assumes you and the mirror share a reference frame and are measuring your speed relative to another frame whereas Zassou assumes that you are measuring your speed relative to the mirror (and traveling toward it).
With regard to Zassou's answer, it is true that Lorentz contraction occurs, but, since you are the observer, it would appear as though mirror were "contracted like a pancake" and that it appears to experience time more slowly relative to you. From your point of view, everything would appear normal except for the absurdly fast approaching mirror. It is also worth noting that if you assume the opposite direction of travel your image would be red-shifted.
AdamRedwine
  • 5,053
Mass can only approach $C$. However, at any speed $<C$ if the mirror were traveling with you, say you hold a mirror in your hand to comb your hair, then everything would appear normally just as if you were standing still. Because in your frame of reference you could consider yourself as standing still and everything else as moving past you
You can not travel the speed of light, you can only get close to it and the closer you get the more relativistic effects you experience, but we can continue talking about the problem you posed in the context of approaching the speed of light.
From your perspective
As you approach the speed of light, the mirror actually gets closer from your perspective and the speed of light both approaching you from the mirror and leaving you moving toward the mirror is $c$. However, you still perceive the mirror moving toward you. So if the mirror is moving toward you at $0.99 c$ and the light from it is coming at you at $c$, then the light from the surface of the mirror only departs at a relative speed of $0.01 c$, which for the context of this discussion we'll say is not very fast.
From the mirror's perspective
The mirror is a part of an inertial reference frame that "observes" (which is really just a formalism for relativity, different than seeing with photons obviously) you moving toward it at $0.99 c$ and let's also note that you are length-contracted like a pancake and experience time more slowly according to the mirror. Light comes from the spaceship (I presume) at $c$ and moves toward the spaceship at $c$. The light that the spaceship emits only moves $0.01 c$ faster than the speed of the spaceship.
In both cases it is agreed that the light from the spaceship emitted at a time $t$ before collision with the mirror only hits the mirror a small amount of time before the spaceship itself slams into the mirror (specifically $0.01 c t$, and yes I know this isn't an objective time measure as I have used it here). In the limit of going exactly the speed of light, then of course, no light from the spaceship is able to reach the mirror before the collision. A reflection of the spaceship in-travel is impossible in this case.
So what do you see?
You see reflections in the mirror from before you started your speed-of-light trip. If we talk about going close to the speed of light, like $0.99 c$ then you see a highly blue-shifted version of yourself for a short period of time (relative to the duration of the trip) right before you crash into the mirror.
Alan Rominger
  • 21,318
Simple answer: no.
Reason: Let's say you are a photon. A mirror is placed in from of you. If you do not smash in to it then it is traveling as fast as you. there for, the photon will never reach it to be redirected backwards.
At relativistic speeds, one does not simply add and substantial relative speeds. In other words, light reflecting off of a mirror traveling at 0.99c does not bounce back at (1-0.99)c, but bounces back at c. Worth reading up more in this.
-2
Traveling in a speed of light with a mirror my studies tell me that you cant see your own reflection wich is true traveling at a speed of light is possible the question is will you see your own reflection wich the answer is no why? That because you travel so fast that time slows in your mind and with the right force of motion you see a dimensional happening in the mirror all you see now is a mirror that is empty.
