-2
I have hit what seems to be a contradiction concerning entropy.
In my class, we measured the entropy change of photosynthesis which is obviously a non-spontaneous process. We used the formula, $$\Delta S_{universe}=\Delta S_{system} +\Delta S_{surroundings}.$$ For this process, we found that the entropy change of the universe was negative. That makes sense, but, I was told that for an isolated system, the entropy change of the universe is always greater than or equal to 0.
So I seem to have hit a contradiction because we can think of the universe as an isolated system, so the entropy change for the universe must always be greater than or equal to 0, but for the photosynthesis process, we found the entropy change of the universe to be negative.
My question is, when can the entropy change of the universe be negative and positive, as we consider the universe to be an isolated system.
If you want to know how we calculated the entropy change of the universe for this process, it is below:
We found the entropy change of the universe for the photosynthesis process to be negative. So here is the chemical reaction. $$6CO_2 +6 H_2O\to C_6H_{12}O_6 + 6O_2.$$ To find the entropy change of the system, we took the standard entropy changes of products minus reactants and got -262 J/mol K. Now this process is at constant pressure, so for the entropy change on the surroundings, we can use the heat of the system, which is equal to the enthalpy change of the system is also equal to the negative of the enthalpy change of the surroundings. We found $\Delta S_{surr}=-9398$ J/mol K. So the sum is -9.66 kJ/mol K
Kyle Kanos
  • 29,127
You found nothing of the sort. You instead found that a tiny, tiny fraction of the photons emitted by the Sun hit the Earth, and that a tiny fraction of those photons that do hit the Earth trigger an endothermic reaction. The second law of thermodynamics does not prohibit such a reaction.
In arriving at your conclusion, you ignored all of those photons that hit the Earth and merely made the Earth get a bit warmer, you ignored all of those photons that didn't hit the Earth, and you ignored the fusion processes at the center of the Sun that ultimately created those photons. Those fusion processes are the second law of thermodynamics at work. The energy released by those fusion processes represent a very large increase in entropy. The slow process by which that energy makes its way to the surface of the Sun: That's also the second law of thermodynamics at work. This transfer diffuses energy from the Sun's core throughout the Sun. The thermal photons emitted by the Sun is yet another example of the second law of thermodynamics at work. This disperses that energy throughout the universe.
The second law of thermodynamics does not say that every process that happens must increase entropy. Energy can be harnessed to locally decrease entropy. The second law puts limits on that decrease, but it does not say that such reactions cannot happen. For example, I use my air conditioner during the summertime to decrease the entropy of my house. This does not violate the second law of thermodynamics. The entropy of the universe increases when I use my air conditioner. And as you found, plants use energy to locally decrease entropy in the plant. This does not violate the second law of thermodynamics. The entropy of the universe increases.
David Hammen
  • 42,721
  • 81
  • 129
-1
ΔS universe = ΔS system +ΔS surroundings .
hotosystem I of plants has a quantum efficiency of 0.99 and an energy efficiency of >0.96. The system may be considered a canonical ensemble which consists of a Thermal bath in which the particles are suspended and monochromatic light emitted ny an incandescent lamp with a definite Tr. Please note that the lamp does not form part of the system, just as for heat exchanges in a thermodynmic system one does not consider the heating element. Now this system violates the second law. By absorption the ΔS of the light field decreases by 4/3 Uv/Tr, where Uv = hv. The absorption process for a mirror absorption/emission pigment such as chlorophyll has deltaS = 0. There are also no other entropy changes in the photosystem itself (configurationS = 0) and the small amount of heat and fluorescence emitted (quantum yield (0.99) is less than the entropy loss by the light field. So the entropy balance is negative.
