Page 580, Chapter 12 in Jackson's 3rd edition text carries the statement:
From the first postulate of special relativity the action integral must be a Lorentz scalar because the equations of motion are determined by the extemum condition, $\delta A = 0$
Certainly the extremeum condition must be an invariant for the equation of motion between $t_1$ and $t_2$, whereas I don't see how the action integral must be a Lorentz scalar. Using basic classical mechanics as a guide, the action for a free particle isn't a Galilean scalar but still gives the correct equations of motion.
Larry Harson
  • 5,456
First, observe that although the non-relativistic Lagrangian is not invariant. It changes by a total derivative, thus the equations of motions remain invariant. The reason of the difference between the Lorentzian and the Galilean cases is that the group action of the Lorentz group on the classical variables (positions and momenta) is a by means of a true representation, while in the case of the Galilean group the representation is projective. In the Language of geometric quantization, $exp(i \frac{S}{\hbar})$, where $S$ is the action is a section in $L \otimes \bar{L}$, where $L$ is the prequantization line bundle and $\bar{L}$ its dual. In other words, the action needs not be a scalar, only an exprssion of the form: $\bar{\psi}(t_2)exp(i \frac{S(t_1, t_2)}{\hbar})\psi(t_1)$, where $\psi(t)$ is the wavefunction at time $t$ and $S(t_1, t_2)$ is the classical action between $t_1$ and $t_2$. The reason that the representation in the Galilean case is projective is related to the nontriviality of the cohomology group $H^2(G, U(1))$ in the Galilean case in contrast to the Lorentz case. I have given a more detailed answer on a very similar subject in my answer to Anirbit: Poincare group vs Galilean group and in the comments therein.
Yest, it must. It does not guarantee that the equations have physical exact solutions but at least everything looks relativistic.
The key point made by Jackson here is that the Lagrangian is physically significant since it determines the equations of motion; via the extremum condition as it so happens.
Firstly, the action integral is taken along a path which is a Lorentz invariant. Secondly, since the Lagrangian is physically significant, then it should also map the same domain to the same real number from the first postulate of Special Relativity. It then follows that the action integral has to be a Lorentz scalar.
Larry Harson
  • 5,456
