I'm curious about the P,T,C-parity of graviton?
1)Are these graviton's parities even or odd?
2)Is the C,P,T-parity alternatively conserved in Einstein gravity? And does the CPT theorem still hold in Einstein gravity?
3)And do these conservations rely on the background space-time?
346699
  • 6,211
About CPT-conservation.
If you talk about graviton then you talk about linearized GR.
There is theory which tells us that all irreducible representations $\left(\frac{n}{2}, \frac{m}{2} \right) \oplus \left( \frac{m}{2}, \frac{n}{2}\right)$ of the Lorentz group is invariant under $C, P, T$ transformations. The theory of graviton (it may be defined without using GR) is the theory $\left(2, 0 \right) \oplus \left( 0, 2\right)$ (graviton is massless particle with helicities $2, -2$), so indeed this theory is invariant under $C, P, T$ transformations.
