When peeling a sticker off its base, the immediate reaction is that it curls; why is this? I am having trouble finding an answer to this. Could it be that the glued side expands upon contact with the air? And, on a somewhat related note, is this a similar reason for why a ribbon curls when glided over with a blade?
*When peeling a sticker off its base, the immediate reaction is that it curls; why is this?
on a somewhat related note, is this a similar reason for why a ribbon curls when glided over with a blade?*
The two phenomena are not different: in the second case you you pull the ribbon across the blunt side of the blade of the scissors (or other tool), and at the same time you press a finger or your palm against the ribbon on the other side, creating a sharp angle of roughly 180° (shaped like a U) around which the ribbon has to bend . This bending takes the fabric beyond its elastic limit and leaves it permanently bent.
In the first case you have the same phenomenon, the glue might some special properties but its role is negligible: usually when you remove a sticker you pull it almost horizontally holding it with your thumb while sliding your index finger on its surface, and thus making an angle of roughly 170° (allowing for the thickness of your finger). Plastic material is made by polymers and these are deformable only to a certain extent: synthetic fibres can withstand a certain amount of stretching or bending without being permanently deformed. If the fibres are deformed too much, the polymer molecules cannot be straightened again, so the shape of the fibres is permanently changed.
From wiki: Plasticity in amorphous materials Crazing
In amorphous materials, the discussion of “dislocations” is inapplicable, since the entire material lacks long range order. These materials can still undergo plastic deformation. Since amorphous materials, like polymers, are not well-ordered, they contain a large amount of free volume, or wasted space. Pulling these materials in tension opens up these regions and can give materials a hazy appearance. This haziness is the result of crazing, where fibrils are formed within the material in regions of high hydrostatic stress. The material may go from an ordered appearance to a "crazy" pattern of strain and stretch mark
Please note that ribbons for decoration are called curling ribbons
because the are expecially made to curl, or usually poly ribbons as they are made from polymers, like the stickers. Sometimes they are still made of cotton or silk (which is very expensive)
- 5,862
The reason that a sticker curls when it is peeled, is that the force needed to peel it off, stretches the the bottom (the glued side) of the sticker beyond its elastic limit. This causes the bottom to be longer than the top, causing it to curl up. The same principle applies to a ribbon that is being bent over a sharp edge.
- 2,573
