12
If dark energy contributes mass-energy density $\rho$ and pressure $p$ to the stress-energy tensor, then you can define $w=p/\rho$, where $w=-1$ gives a cosmological constant, $w<-1$ gives a big rip, and $w<-1/3$ if we want to use dark energy to explain cosmological acceleration. The WP "Big Rip" article cites a paper that dates back to 2003 http://arxiv.org/abs/astro-ph/0302506 , which states that the empirical evidence was at that time only good enough to give $-2 \lesssim w \lesssim -.5$.
Have observations constrained $w$ any more tightly since 2003?
I've heard many people express the opinion that $w<-1$ is silly or poorly motivated, or that "no one believes it." What are the reasons for this? Other than mathematical simplicity, I don't know of any reason to prefer $w=-1$ over $w\ne -1$. Considering that attempts to calculate $\Lambda$ using QFT are off by 120 orders of magnitude, is it reasonable to depend on theory to give any input into what values of $w$ are believable?
Kyle Kanos
  • 29,127
I do not know if this answer will address fully your Question, anyway:
Clustering of Photometric Luminous Red Galaxies II: Cosmological Implications from the Baryon Acoustic Scale (2011/Apr)
Combining with previous measurements of the acoustic scale, we obtain a value of $w_0$ = -1.03 +/- 0.16 for the equation of state parameter of the dark energy
cited here : Cosmology today–A brief review (25 pages on Theory and data, 2007/Jul)
You can find a new model of the Universe without Dark Energy here:
A self-similar model of the Universe unveils the nature of dark energy (21 pages Jul/2011, not peer-reviewed, it uses only Newton and Coulomb laws). I do not know how this novel viewpoint can be discarded.
Argument:
From $$F=m\cdot a,\, F=G\cdot\frac{m_{1}\cdot m_{2}}{d^{2}},\, F=\frac{1}{4\pi\varepsilon_{0}}\cdot\frac{q_{1}\cdot q_{2}}{d^{2}},\, c=\frac{1}{\sqrt{\varepsilon_{0}\mu_{0}}}. $$ obtain the dimensional equations $$\left[G\right]=M^{-1}L^{3}T^{-2},\left[\varepsilon\right]=M^{-1}Q^{2}L^{-3}T^{2},\left[c\right]=LT^{-1}$$ because the the sum of the exponents is zero, a cute coincidence ;), we know that $[M],[Q],[L],[T]$ can scale in the same way and $[c],[G],[\varepsilon]$ are constants. If the universe can scale thru time, keeping always the same basic physical laws, it will scale.
The scaling law $\alpha(t_{S})=e^{-H_{0}\cdot t_{S}}$ is derived from the observational data, where $t_S$ is considered from the viewpoint of a comoving invariant referential, and Dark Energy is absent from it.
The accelerated expansion is an artifact of the standard model
The statement that space expansion is accelerating is not the result of some direct measurement more or less independent of the cosmological model but, on the contrary, it is a consequence of the theoretical framework of the standard model. The deceleration parameter at the present moment, $q_{0}$, in the $\Lambda$CDM model, for flat space and $\Omega_{R}=0$ , is given by $q_{0}=\frac{1}{2}\left(\Omega_{M}-2\Omega_{\Lambda}\right)$ therefore, for $\Omega_{M}+\Omega_{\Lambda}=1$ , the value of $q_{0}$ is negative for $\Omega_{\Lambda}>1/3$ ; a value of $\Omega_{\Lambda}$ lower than 1/3 leads to a comoving distance largely in disagreement with observations, hence, in the framework of $\Lambda$CDM model it has to be $\Omega_{\Lambda}>1/3$ and, so, $q_{0}<0$ .
(Needless to say: this is my preferred viewpoint because it has no free lunches: growing space, growing dark energy, and apply to all scales, even to Solar system)
Helder Velez
  • 2,685
