17
Imagine a sphere of black holes surrounding a piece of space. Will this piece be separated from the rest of normal spacetime (at least for some time, till these black holes finally attracted themselves).
So, seen from the outside, we have a black hole, but with a non-singular interior.
Is this possible?
draks ...
  • 1,002
The radius of the event horizon of a black hole of mass $m$ is given by:
$$ r_s = \frac{2GM}{c^2} \tag{1} $$
Let's consider your idea of taking $n$ black holes of mass $M$ and arranging them into a sphere. The total mass is $nM$, and the radius of the event horizon corresponding to this mass is:
$$ R_s = n\frac{2GM}{c^2} \tag{2} $$
Now let's see how closely we have to pack our black holes to get them to form a spherical surface with their event horizons overlapping. The cross sectional area of a single black hole is $\pi r_s^2$, and since we have $n$ of them their total cross sectional area is just $n \pi r_s^2$. the surface area of a sphere of radius $R$ is $4\pi R^2$, and we can get a rough idea of $R$ by just setting the areas equal:
$$ 4\pi R^2 = n \pi r_s^2 $$
Giving us:
$$ R = \frac{\sqrt{n}}{2}r_s $$
Use equation (1) to substitute for $r_s$ and we find that the radius of our sphere of packed black holes is:
$$ R = \frac{\sqrt{n}}{2}\frac{2GM}{c^2} \tag{3} $$
Bit if you compare equations (2) and (3) you find that $R < R_s$ because $\sqrt{n}/2 < n$. That means when you try and construct the sphere of black holes that you imagine you won't be able to do it. An event horizon will form before you can get the individual black holes to overlap. You won't be able to construct the black shell that you want and it's impossible to trap a normal bit of space inside a shell of black holes.
However there is a situation a bit like the one you're thinking about, and it's called the Reissner–Nordström metric. A normal black hole has just the single event horizon, but if you electrically charge the black hole you get a geometry with two event horizons, and inner one and an outer one. When you cross the outer horizon you enter a region of spacetime where time and space are switched round, just as in an uncharged black hole, and you can't resist falling inwards towards the second horizon. However when you cross the second horizon you're back into normal space. You can choose a trajectory that misses the singularity and travels outwards through both horizons so you re-emerge from the black hole. If you're interested I go into this further in my answer to Entering a black hole, jumping into another universe---with questions.
As for what the spacetime inside the second horizon looks like, well it's just spacetime. It's highly curved spacetime, but there's nothing extraordinary about it.
John Rennie
  • 367,598
It is in principle possible, at least for some time, to have a collection of black holes gravitating along the surface of a sphere such that one can still escape from the inside of that sphere. In other words, the inside of the sphere need not be hidden behind a gravitational horizon.
However, as soon as the density of black holes exceeds a critical value, a black holes merger is unavoidable and the whole collection of black holes will collapse into one giant black hole. For a large number $N$ of black holes this critical density is very small. General relativity tells us that a black hole merger is unavoidable as soon as the collection of $N$ black holes, each with horizon circumference $l$, fits within a sphere of circumference $N l$. This means that even if you would have no more than a ring of black holes that are close to touching (I.e. their horizons being close to overlapping) you would not be able to prevent a giant black hole merger.
Johannes
  • 19,343
There is a known example where it looks like a black hole on the outside but is flat spacetime on the inside. Imagine the funnel shaped exterior of a black hole and take the entire part outside of the event horizon, which is a spherical shell of surface area $4\pi r^2$. Then take a spherical ball of Minkowski space of radius $r$ and sew the two together spaces together along the common spherical shell of surface area $4\pi r^2$. Thinking back about the funnel picture of the black hole it is like replacing the lower part of the funnel with a flat disc.
There will be a curvature discontinuity where you sewed the two vacuum solutions together so you need a concentrated stress-energy at that surface between the two vacuum solutions. This can correspond to a spherical shell of particles or fluid with no rest mass moving away from the center point at the speed of light, but placed exactly on the event horizon so it doesn't get any farther from the center.
So: black hole solution on the outside, flat space on the inside, just like you asked about. However, it is very unstable, any tiny change and the inside will collapses to a singularity on the inside. Plus we don;t know of anything that can move at the speed of light yet also be confined to an infinitesimally thin spherical shell. So it's more a mathematical example than a practical one, but it does show that just because something looks like a black hole on the outside, it doesn't have to be anything other than flat on the inside if we are OK with exotic things confined to infinitesimally thin regions.
I first learned about this solution from the American Journal of Physics, I'll edit this sentence when I find the reference.
Timaeus
  • 26,055
  • 36
  • 71
