Does gravity effect the "sphericalness" of the Coulomb force?
For example, is the field 1 meter above a charge weaker than the field 1 meter below the charge?
Could a 0.014% difference in the field be detected?
Have there been any such experiments run?
Edit:
In answer to firtree's question below, I am working on the admittedly heretical idea that the "curvature of space" is actually the flow of space into a massive body and as such space is flowing into Earth at 11km/s at its surface (its escape velocity).
At the moment, I'm trying to develop a model for length contraction. Using the notions of perturbation theory and $r=ct$ one could perhaps reformulate Coulomb's Law: $$F(r)=\frac{q_1q_2}{\epsilon_0}\frac{1}{4\pi r^2}$$ as: $$F(t)=\frac{q_1q_2}{\epsilon_0}\frac{1}{4\pi c^2t^2}$$ Time moving against the flow: $$t_u=\frac{d}{c-v}$$ and with the flow: $$t_d=\frac{d}{c+v}$$ The 0.014% comes from comparing the force for the two times plugging in $d=1$ and $v\approx11,000$ m/s
However, as the calculation of length contraction illustrates, the actual effect is dependent on the two way speed of light. And aside from that, if things actually worked this way it would seem to violate Newton's 3rd law. But, I just wanted to get a sanity check and see if there were any experimental (or theoretical) results related to this.
aepryus
  • 1,021
Yes gravity affects voltages and forces in circuits but has very small effect
suppose you have vertical wire on globe directly which is 1 meter ,electron mass is 10 power -31 kg,and you know globe mass and radius , by simple calculations depending newton's law of gravity and work's law you get:
the voltage gravity applied on wire is 10 power -26
and it is nothing!
deaa
  • 49
