-1
Let through a straight wire flow an electric current. Using a compass needle how the needles tip will be directed to the wire? What happens when we switch the current direction and approach the needle again to the wire?
To get a source will be nice, but nicer it will be to get an answer from experiment which unfortunately I didn't in the past and not able to do at the moment.
HolgerFiedler
  • 10,980
I doubt my description can be improved other than with a picture.
Direction of a compass needle caused by a flow of current
Now the interesting thing here is that I do not know which way the current is flowing, because I do not know which way the compass needles are colour-coded. I guess that the red represents the north pole. I do know that if the current flow is reversed then the needles will swap direction.
It really doesn't greatly matter. There is a defined direction and it is a convention that arises from the definition of vector product, the definition of conventional current flow and the sign convention in Ampere's law relating the curl of the B-field to the current density.
ProfRob
  • 141,325
