I have GPS in my phone but I have only a very rough idea of how it works. I have checked the Wikipedia article but that gone over my head (I can not understand that maths and other strange stuff there). Please explain its working in simple words.
What I think is that it sends signal to satellites, satellite checks the location of sending device and reply with the location of that device.
Emilio Pisanty
  • 137,480
SMUsamaShah
  • 5,507
GPS signal is actually a time signal. Each satellite sends data that includes:
  • time according to the satellite's clock
  • location of the satellite (or data where the location can be calculated)
  • some error correction data
Now, the receiver calculates the distance to the satellites: distance = time * velocity. Velocity is a known constant (+- the error correction). The receiver then gets multiple distances to different satellites so it can calculate the its location.
Note that four distances to known locations (satellites) are enough to determine the location of the receiver. Imagine that you tie four strings to four different stationary objects and other ends of the strings to your finger. There is only one (or none) position where all the strings are tight.
To be more accurate, the time in the above equation is relative to the time of the other satellites. In short, you need one satellite to be your reference time. The longer explanation is that there is an additional free parameter which requires you to solve a group of equations. See comments and Ibrahims answer for more details.
Juha
  • 798
There are 24 satellites around the world each of them transmit:
  • The current time on their clock
  • Their location relative to earth
The distance between us and a satellite must be equal to the difference in time it took to receive the data sent by the satellite multiplied by speed of light(c). d=(t2-t1)*c.
Remember how in math the distance between two points is d = sqrt((x1-x2)^2+(y1-y2)^2)). The same equation is used but now we have x,y,z instead of just x,y.
Looks like we have 3 unknowns which is the position of the receiver (x,y,z). However there is a bias in the time due to relativity and computational delays. Since the value of c is so big, it can create large errors, we treat this bias as an unknown as well.
So we have unknowns we need four equations to solve the problem. Therefore we use the distance equation with 4 different satellites. We get four non-linear equations, which is a minimum to lock your position, but if there are more satellites available more equations can be used to give better results.
These equations are solved iteratively since they are non-linear. You cannot used the elimination and back-substitution method(which is taught in school math classes). The processor repeatedly solves the set of equations using an initial guess and each time using results of the previous iteration as the guess to get better results until it reaches a point where another iteration gives a very small change.
GPS receivers calculate position first in a coordinate system known as ECEF XYZ. That just means Earth Centered Earth Fixed xyz. The WGS84 defined center of the earth is given the coordinates 0,0,0. The x-axis extends from that center, to a point at the equator where the longitude is 0 and of course, in the negative direction to a point at the equator where the longitude is 180 degrees. The y-axis extends from the origin at the center of the earth, to a point at the equator where the longitude is 90 degrees east (for the + direction) and longitude 90 degrees west (for the -direction). Lastly, the z-axis is the same as the earth's polar axis. That is, it extends to the north pole (+) and to the south pole (-). This is all fine and dandy, but if I gave you coordinates of a position in this coordinate system, few people would be able to tell even roughly where that was. We're all much more familiar with latitude, longitude and elevation. So usually, GPS manufacturers will translate the ECEF XYZ coordinates to lat/lon/elev coordinates that we can understand. For latitude and longitude.
GPS receivers are just that. your phone transmits its location when it does its handshake to the closest cellular antenna.
Fortunato
  • 744
I think it should be mentioned that the (atomic) clocks on the satellites are running (ticking) faster than the clocks on the Earth's surface due to the relativistic effects - time dilation due to the satellite's motion relative to the Earth (Time dilation) and due to the difference between the gravitational potential on satellite's orbit and at Earth's surface (Gravitational time dilation).
Engineers must take these small effects into account, otherwise the GPS wouldn't give you your correct location (the time difference on clocks will continuously grow with time so the position errors will grow too and the GPS will become worthless as a navigational system).
kuzand
  • 2,196
  • 20
  • 37
