I read in reliable sites that GR and classical physics calculate the angle of deflection in the same manner. The formula is almost identical: $$\theta = \frac{4GM}{c^2*r} \rightarrow \frac{4GM}{c*r} = v *\frac{1}{c}$$ GR modifies the formula adding a factor $ \theta = \frac{4GM}{c^2r}\times \frac{1+\gamma}{2}$ where gamma has value 1 for energy and 0 for mass, so that the classical laws apply to orbits $ \theta = \frac{2GM}{c^2r}. $ Now if I did not misinterpret the procedure, they find the g-pull at point of impact R $g = \frac{GM}{R^2} $ and then integrating over time they get the normal velocity the ray acquires from gravity $v = \frac{[2*]2GM}{R\times c}$ In the case of the Sun this value is [2*]127400 cm/s. Then, considering v and c the legs of a right triangle, they consider v/c (254800/3*10^10) the tangent of the angle theta (the angle of deflection in radians) and since theta is a small angle, they identify the value of the tangent with the angle itself. Also John Rennie did this here:(Deflection of light by the Sun)
the equation I gave is an approximate equation that works when θ is small. At these small angles the difference between θ and tanθ is negligible.
If my report is correct (please forgive any blunders), I have a couple of questions:
If you consider the result of the integral (254800 cm/s) a vector of velocity v, why don't you follow the regular addition of vectors?
Why should the angle between two vectors be intended in radians and not in degrees. What is the rationale?
If you think that $v/c$ is really the tangent of the angle of deflection, why use the subterfuge of approximation and not find the exact angle using the appropriate function of $\mathrm{arctan}$, $\mathrm{tan}^{-1}(v/c)$?
@NaturalPhilosopy, that "doesn't make sense" I wrote in the question. Of course you are only reporting the literature, but I hope you, or someone here, realize that that is not rational, scientific. Why sould you assume anything? why should you deviate from the standard optimal math procedure? what is the logic, the rationale? you know the tangent, want to find the angle : arctan. And what if the angle is not so small? suppose v = c, then tan theta = 1, what do you do? Lastly, if you calculate the effective angle theta with tan= 254800/3*10^10, you discover that the difference is not that negligible.
@Jerry Schirner, sure, radians has a meaning but so do many other things in math. The fact that it is meaningful doesn't mean that it is relevant, appropriate here. That is not enough to justify, logically and physically that the ratio between two normal vectors corresponds to as many radians. Has anybody ever proved that? Can you do that?
