I think I've come across a paradox while studying general relativity. Wikipedia states that the deflection angle of light by a point mass is $4GM/(c^2b)$.
http://en.wikipedia.org/wiki/Gravitational_lensing_formalism
Where b is the impact parameter, the limit of the perpendicular distance of the light ray from the point mass as the light gets far away. By shining a light that gets pulled close to the photon sphere of a black hole I can make a photon orbit the black hole an arbitrary number of times before escaping, leading to a deflection angle much greater than 2*pi. However, to make this angle go to infinity (at the photon sphere) according to the equation, I need to make b go to zero. However, if I shine a light very close to to center, it passes the event horizon and will go into the black hole without orbiting forever. What am I missing in this analysis?
nahano
  • 569
That formula is an approximation derived in linearized GR; it's not correct near a black hole.
(The test particle is non-Newtonian, since it's traveling at c, and that's why the answer can differ so much from the Newtonian prediction even though the gravitational field is assumed to be weak.)
benrg
  • 29,129
