12
Layman here,
Stumbling through some physics stack posts and started reading the Wikipedia for the chronology of the big bang. In it, it states
The very earliest universe was so hot, or energetic, that initially no matter particles existed or could exist except perhaps fleetingly, and the forces we see around us today were believed to be merged into one unified force. Space-time itself expanded during an inflationary epoch due to the immensity of the energies involved. Gradually the immense energies cooled – still to a temperature inconceivably hot compared to any we see around us now, but sufficiently to allow forces to gradually undergo symmetry breaking, a kind of repeated condensation from one status quo to another, leading finally to the separation of the strong force from the electroweak force and the first particles.
Where is the "immense energy" going to when it is "cooled"? Is there now no "immense energy"?
When the universe expands, it is important to understand that how its energy content evolves depends on the form of energy involved. If all that energy is locked up in the form of mass energy, then the density of that matter will decrease proportionally to the relative increase of any arbitrary volume of the universe (i.e. if expansion doubles the size of things, all volumes will be multiplied by 8, and correspondingly all densities will be divided by 8). In other words, if $a$ is the scale factor of the universe, and $\rho_m$ its matter density, we have :
$$ \rho_m \propto a^{-3} $$
Hence, the total amount of mass energy (which is $\rho_m \times a^3$) is conserved. What happens if the energy content of the universe is dominated by radiation ? In that situation, on top of the decrease in density, radiation is also redshifted proportionally to the scale factor. Hence, if $\rho_R$ is the radiation energy density, we have :
$$ \rho_R \propto a^{-4} $$
Here, the total energy ($\rho_R \times a^3$) is not conserved, which, remember, is not a problem in General Relativity. The period your textbook is referring to is likely the radiation era (roughly the first $50,000$ years of the universe's history). Indeed, during this time, the universe cooled in a way that decreased the total energy of the universe. It didn't go anywhere, it is indeed "lost" in a sense.
Conversely, we can have a situation where energy is gained. This is the case for any dark energy model, but let's keep it simple and consider the case of a cosmological constant $\Lambda$. This corresponds to a constant energy density. That is to say $\rho_\Lambda$ is independent of $a$. The total energy will then be $\rho_\Lambda \times a^3$, and will therefore increase with expansion.
Here I loosely used the word "total" given that it doesn't mean much in an infinite universe. A more rigorous expression for "total" would be any arbitrarily chosen sphere in comoving coordinates, so long as its radius is above the inhomogeneity scale.
ticster
  • 1,905
Temperature means energy. The heat energy is still here. It's just that the "object" (the Universe) grown bigger so this energy had to spread through it. The more energy in a single point, the hotter it is. That's why they say it got cooler. It's like the expanding gas from your spray deodorant is cold when it leaves the can, but it was at room temperature inside the can. The energy is still the same.
Please note that this is just a simple analogy and it should be aknowledged that there are much more complex processes involved. It was asked for an Layman's answer.
-2
In the case of nuclear fusion, a large amount of heat and thrust is generated. At the time of Big Bang, the process was just opposite. nature was consuming the cosmological substance like heat and thrust to create mass using Higgs field. Hence the cooling process was just a natural process. Pramod Kumar Agrawal
