Here we have a wire. At both ends there is an equal and opposite field caused by a chemical reaction. So, if we decrease or increase the distance between the two points, the strength of the field increases/decreases with the square of distance. Why then is resistance linearly proportional to distance then?
“[A]n equal and opposite field” is an oxymoron and gibberish. Henceforth I’ll assume that we have a chemical voltage source there.
The Coulomb’s law is applicable in the case of a charged body, a body that has a constant electric charge. A chemical voltage source is a completely different situation: there is no pre-defined distribution of charges (as they move easily through conductors, electrolytes, and so), but there is a pre-defined difference of electrostatic potential on the ends of the source. How is it compatible with the Coulomb’s law? I already answered: charge carriers can move and adjust their position to create and maintain the potential difference (for the question why do they do it address the Battery and current confusion? topic).
If a wire with uniform cross-section and resistivity is attached to the source, then a dynamic equilibrium is formed: charge carriers drift along the wire with a constant average speed, but there is no change in the charge density in it. Okay, why the electrostatic potential distribution in the wire is such that the field strength is constant, that the voltage drop is constant for a unit of length? Because it is an equilibrium! If somewhere in the wire the field will become weaker, then electrons will drift slower in this section, so density of electrons will change (I’ll not explain it in details, but it is easy to imagine) in the way that the difference in the field strength will defuse quickly. Really such fluctuations take place, but variations in electrons’ density are insignificant because even a small such variation would produce a strong field.
- 833
The answer-as requested by HDE. So my foolish misconstruct of the electric field is that since it accelerates charged particles more or less depending on the distance from the source, it should create less motion in electrons a further distance from the source.
I'm not sure why I thought resistance had much to do with it-on further analysis resistance makes linear sense, since it takes twice as much energy in twice as much wire given that a particle gives off heat energy dependent on how much wire it travels through.
The problem with my initial idea-which at least was a valid question- is that electrons self-balance. If a pocket of electrons spreads out more near the source and less further from the source, the clumping further from the source will try to spread out, and the spread out part will come together to achieve coulombic balance.
Overarching idea-balance of charge.
My problem was the act of clustering of charge that initially occurs, to which I was like: why does this not become an issue? A valid question at least.
- 668
- 1
- 7
- 16
