16
I wonder, are there any fundamental issues leading to reduced performance of Peltier elements at cryogenic temperatures (-100C and lower)?
What is theoretical/practical minimum temperature achievable by a cascade of Peltier elements, provided that each next element have about 3 times less power than previous in cascade, so that they are not overwhelmed by selfheating? Let's say first element is water-cooled down to 20C when dissipating 150W.
Update: After extensive tests, I've found out that in any setup I cannot get below -19C using any number or combination of Chinese (r) Peltier elements (I've tried alot of different ones in different combinations).
BarsMonster
  • 2,492
I do not know any fundamental minimum of Peltier elements operation temperature.
However, there are serious technical issues: as long as Peltier effect relies on an interaction between electrons and phonons, there should be enough phonons to interact with. Decreasing temperature dramatically (though quantitatively, not qualitatively) changes effectiveness of the elements. As long as heat pumping should overcome heat produced by electron current which produces this pumping, going to low temperatures is a challenging task.
To sound more scientific, I've found this relatively new paper (also available here)where Peltier effect is discussed for some rather standard system and where curves at room and liquid nitrogen temperature (which is low by human standards but pretty warm from cryogenic point of view) and its effectiveness may be found (see Fig. 3). As can be seen from the curves, Peltier element is able to give $\Delta T$ around few degrees at nitrogen temperature. So, it stil works at 77K but definitely far less effective than at room temperature. With numbers given on graph I can hardly imagine the cascade which will do these 77K out of room temperature.
In this paper authors claim that effect may be observed at 6K, but the numbers they give show that this effect may be hardly used in practice.
To conclude, it seems there is no definite theoretical limit, but practical limit is around -100C
uhoh
  • 6,089
Misha
  • 3,387
A got -28°c. I used only one TEC-12710(160W) with a modified water cooler, I changed the fan of radiator for a industrial blower.
I believe that one TEC-12730 with a more powerfull cooling device will reach extreme low temperatures.
