22
The standard lore in relativistic QFT is that poles appearing on the real-axis in momentum-space Green's functions correspond to particles, with the position of the pole yielding the invariant mass of that particle. (Here, I disregard complications tied to gauge-fixing and unphysical ghosts)
Schematically, I take this to mean:
$$\text{one particle state} \Leftrightarrow \text{pole on real axis}$$
It is easy to show the correspondence going $\text{particle} \Rightarrow \text{pole} $. This is done in many textbooks, e.g. Peskin and Schroeder's text, where a complete set of states diagonalizing the field theoretic Hamiltonian is inserted into a $n$-point correlator, and a pole is shown to emerge.
However, how does one make the argument going the other way $\text{particle} \Leftarrow \text{pole} $? That is, the appearance of a pole in a Green's function indicates an eigenstate of the Hamiltonian, with the eigenvalue corresponding to the particle energy?
QuantumDot
  • 6,531
For simplicity, take $\hbar=1$ and consider a Hermitian scalar, renormalized field $\phi(x)$; other fields are treated analogously. Then (for simplicity ignoring the necessary smearing since the field is a distribution only) $$G(E)=i\int_0^\infty dt e^{itE}\langle \phi(0)\phi(t,0)\rangle =i\int_0^\infty dt e^{itE}\langle \phi(0)e^{-itH}\phi(0)\rangle\\ =\Big\langle\phi(0)\int_0^\infty dt ie^{it(E-H)}\phi(0)\Big\rangle =\langle \phi(0)(E-H)^{-1}\phi(0)\rangle =\psi^*(E-H)^{-1}\psi,$$ where $\psi=\phi(0)|vac\rangle$, since the vacuum absorbs the other exponential factors. The spectral theorem for the self-adjoint operator $H$ guarantees a spectral decomposition $\psi=\int d\mu(E')\psi(E')$ into proper or improper eigenvectors $\psi(E')$ of $H$ with eigenvalus $E'$, where $d\mu$ is the spectral measure of $H$. Orthogonality of the eigenvectors gives $$G(E)=\psi^*(E-H)^{-1}\psi =\int d\mu(E')\psi(E')^*(E-E')^{-1}\psi(E') =\int d\mu(E')\frac{|\psi(E')|^2}{E-E'}.$$ Therefore $$(1)~~~~~~~~~~~~~~~~~~~~~~~~~~G(E)=\int\frac{d\rho(E')}{E-E'},$$ with the measure $d\rho(E')=d\mu(E')|\psi(E')|^2$. For negative $E$, the Greens function is finite; since the measure $\rho$ is positive, this implies that the integral is well-behaved and has no other singularities apart from those explicitly visible in the right hand side of (1). Note that (1) holds for every self-adjoint Hamiltonian, no matter what its spectrum is. It thus describes the most general singularity structure an arbitrary Greens function can have.
In general, the spectral measure consists of a discrete part corresponding to the bound states and a continuous part corresponding to scattering states. (There might also be a singular spectrum, which is usually absent and does not affect the main conclusion.) Formula (1) therefore says that (in the absence of a singular spectrum) the only possible singularities of the Greens function are poles and branch cuts. Moreover, (1) implies that $G(E)$ has a pole precisely at those discrete eigenvalues $E'$ of $H$ for which $\psi(E')$ is nonzero, and branch cuts precisely at the part of the continuous spectrum in the support of the measure $d\rho$.
In particular, any pole of $G(E)$ must be a discrete eigenvalue of $H$, whereas the converse only holds under the qualification that $\psi=\phi(0)|vac\rangle$ has a nonzero projection to the corresponding eigenspace of $H$.
The above argument applies to quantum field theories after elimination of the center of mass degrees of freedom. Thus we consider the subspace of states in which the total spatial momentum vanishes. On this subspace, the bound states have a finite multiplicity only, as each mass shell is intersected with the line in momentum space defined by vanishing spatial momentum.
In terms of the original question, the direction ''pole $\to$ particle'' holds without qualification, whereas the direction ''particle $\to$ pole'' (claimed by the OP to be the obvious part) is not universally correct but only holds under a nondegeneracy condition.
Particles are very rarely eigenstates of the Hamiltonian.
In particle physics, only (dressed) electrons (and protons?) might be eigenstates. All the other particles have a finite life-time, implying that they decay, which means that they are obviously not eigenstates.
What we want to call a particle is something which has a clear signature in a correlation function and a long life-time compare to its energy. If the theory is perturbative (e.g. QED), the free theory already gives an intuition of what we are looking for: a pole of a Green's function very close to the real axis. Once again, these appear as poles.
In strongly coupled theory (e.g. low-energy QCD), it is much less clear what particles will be if we start from the bare action (quarks+gluons). Nevertheless, there are still particles (stable or unstable, protons and neutrons for instance). There are also resonances (when the life-time is too short).
Finally, there are also strongly-coupled theories where no (quasi)-particles exist. They appear frequently in condensed-matter, and are very difficult to study since one does not have a nice picture in term of scattering, propagation, etc. to figure out what's going on.
Adam
  • 12,192
