I'll assume that you were using a radio tuned to a 1 Mhz frequency ($\omega = 6.3\times 10^6$ s$^{-1}$) and that the radio was completely enclosed inside $t=3\,$mm of pure iron.
There are two important effects to consider. (i) How much power is reflected from the iron surface. (ii) How much of the transmitted power makes it through the iron.
To figure this out we need the properties of iron; a conductivity $\sigma = 10^7$ S/m, a relative permittivity $\epsilon_r \simeq 1$ and a relative permeability $\mu_r \simeq 10^4$ (for 99.9% pure iron).
First we check whether iron works as a good conductor at these frequencies by noting that $\sigma/{\epsilon_r \epsilon_0 \omega} = 1.8\times 10^{11}$; i.e. $\gg 1$ and therefore a good conductor.
The modulus of the impedance of a conductor is given by $\eta({\rm Fe}) = (\mu_r \mu_0 \omega / \sigma)^{1/2} = 0.089$ $\Omega$.
So, now the relevant equations are:
Electric field transmission at the air/iron interface (assuming normal incidence)
$$\frac{E_t}{E_i} = \frac{2 \eta({\rm Fe})}{\eta_0 + \eta({\rm Fe})} \simeq 2\frac{\eta({\rm Fe})}{\eta_0}\, ,$$.
where $\eta_0 = 377$ $\Omega$.
The EM waves then propogate into the metal but are exponentially attenuated on a scale defined by the "skin depth" $\delta = (2/\mu_r \mu_0 \sigma \omega)^{1/2} = 1.59 \times 10^{-6}\,$m.
Thus, after traversing a thickness $t$, the E-field is attenuated by $\exp(-t/\delta)$.
Finally the wave emerges through the iron/air interface on the other side and we use the transmission formula again but with the labels swapped on the impedance values.
Hence the ratio of the net transmitted electric field to the incident electric field is given approximately by
$$ R = 2 \frac{\eta({\rm Fe})}{\eta_0}\, \exp(-t/\delta)\, 2 \frac{\eta_0}{\eta_0 + \eta({\rm Fe})} = 4 \frac{\eta({\rm Fe})}{\eta_0}\, \exp(-t/\delta)\, .$$
For the numbers I've assumed $R \simeq 0$ because the wave traverse $>1000$ skin depths to get through the iron! The transmitted power is $\propto R^2$.
So my conclusion is that enclosing within 3mm of pure iron would certainly block AM radio.
How might this not work? Perhaps the iron you used is very impure and the permeability is orders of magnitudes lower? If $\mu_r =1$ then $\eta({\rm Fe}) = 0.00089\,\Omega$, $\delta = 1.59\times 10^{-4}\,$m. Thus 3mm is still 18 skin depths. The conductivity I assumed is unlikely to be much lower, so I'm a bit confused as to why it wouldn't work.
The demo I use in my lectures is wrapping a mobile phone in aluminium foil. In principle, this is much more marginal because though the frequencies are higher, the foil thickness is much lower, but it certainly works.
