- Is there a reference which explains how the $\langle TT\rangle $ correlation of the boundary conformal field theory (CFT) can be holographically calculated from the bulk gravity? (..I am often getting referred to some paper by Skenderis et. al but I would like to see some more explicit explanation of the idea..)
In the following we defined $C_T$ as the coefficient of the leading singularity of the $\langle TT\rangle $ correlation.
Roughly that I understand the following possible algorithm works -
first expand the gravity Lagrangian about an AdS background making a fluctuation (say $h$ ) along two orthogonal spatial directions of the boundary. Like say add to the metric two off-diagonal components of the type, $g_{xy} = g_{yx} = \epsilon h (r,z)$ where $x,y,z$ are 3 randomly chosen orthogonal spatial directions on the boundary and $r$ is the bulk direction orthogonal to the boundary.
Now pick out all terms in the Lagrangian which are quadratic in $h$ and focus on all the terms which have a $\partial_r$ and rewrite those terms by pulling out a total derivative in $r$. (...I don't know how to make sense of this if one has terms of the kind $(\partial _r h)(\partial_r ^2 h)$ (and such terms do occur in examples I have tried)
Now in this "boundary Lagrangian" which is formed by the total derivatives in $r$ and quadratic in $h$ terms substitute a Fourier expansion for $h$ as $h(r,z) = \sum_p e^{ipz}H_p(r)$.
Now apparently there is (a universal? irrespective of the gravity Lagrangian?) value for this $H$ function which makes the fluctuation go on-shell and for Gauss-Bonnet gravity that apparently is, $H_p(r) = c BesselK[ d/2, (L^2p)/(\sqrt{f_\infty} )]$. And this $c$ is determined by demanding that $H_p (r \rightarrow \infty) = 1$ (where $r=\infty$ is the boundary) [...here its not clear to me as to how will this $f_\infty$ be defined from just the GB Lagrangian - AFAIK this $f_\infty$ is a parameter that is defined only when one is looking for asymptotically $AdS$ blackholes in GB gravity)
Now expand in a power series in $r$ about $r=\infty$ this boundary Lagrangian and then (for any of its Fourier mode $k$?) for a d-dimensional boundary if the $d$ is even then this $C_T$ is given by the coefficient of the $k^dlog k$ terms and for $d$ odd this is given by the $k^d$ term.
- I would like to know if I understand the above algorithm right and if so then what is the reference for its derivation.
