The Lagrangian for a relativistic particle moving in an electromagnetic field is given by $$L = - \frac {mc^2} \gamma + q~( \vec u(t)\cdot \vec A(\vec x,t) -\Phi(\vec x,t))$$
Conservation of the canonical momentum requires the Lagrangian to be independent of coordinates, whereas in general it isn't. We therefore need to show it's possible to create this independence with some suitable gauge transformation of the potentials $\Phi$ and $A$. For the case of a static electric field with $\vec A=0~$, the EM gauge transformations  $$\vec A= \nabla\lambda(\vec x,t),\quad\phi(\vec x)\to\phi(\vec x) - \frac d {dt} \lambda(\vec x,t) $$ gives the Lagrangian $$L = -\frac{m_0c^2}\gamma + q~(  \vec u\cdot\nabla\lambda(\vec x,t) - \phi(\vec x) + \frac d {dt}\vec\lambda(\vec x, t))$$
It isn't generally possible to make this expression independent of coordinates for every $\Phi(\vec x)$ including that for a static Coulomb electric field. However, lets take the simplest case of an electric field directed along the x axis giving a potential and defining a gauge as$$\Phi(\vec x) = -Ex\qquad \lambda(\vec x, t) = -Ext$$to give a coordinate independent Lagrangian$$L = -\frac{m_0c^2}\gamma - q\vec u\cdot Et$$ and the conserved canonical momentum $$\frac{\partial L}{\partial\vec u} = (\gamma mu_x - qEt, 0, 0)$$ Since this is constant over time, we're finally left with just the Lorentz force on a relativistic charge in a static electric field along the x direction $$\frac d {dt}\gamma m\vec u = q(E,0,0)$$
This can be generalised to any time and coordinate dependent electric field from the principle of locality, causality and memorylessness:
- The dynamics of a charge depends upon the field at its coordinates only
- The dynamics of a charge depends upon the field at time t, and not the past or the future.
Therefore, for any electric field $\vec E(\vec x,t)$, the Lorentz force and associated conserved expression is$$\frac d {dt}\gamma m\vec u = q\vec E(\vec x,t),\qquad\gamma m\vec u - q\int\vec E(\vec x,t)dt$$ and  can finally conclude using the gauge $\lambda(\vec x, t) = -\int\Phi(\vec x, t)dt$, canonical momentum is conserved for a relativistic charge in a electric field $\vec E(\vec x, t)~$ and given by $$\frac{\partial L}{\partial\vec u} = \gamma m\vec u - q\int\vec E(\vec x,t)dt$$
