-1
What if somebody says that Sun orbits around the Earth and not Earth orbiting around the Sun?
What would be the consequences?
The earth and sun revolve around a "barycenter" BUT since the earth and sun are NOT a "2 body system" the actual, exact, precise barycenter is impossible to calculate or predict. It is NOT incorrect to say the earth revolves around the sun...
A pair of bodies in space revolve around their mutual center of gravity, called the barycenter.
The issue can be tackled in Newtonian physics, more precisely in Newtonian dynamics.
As motion is a relative notion, there is no hope to answer exploiting kinematic notions only (I am referring to the case where only Sun and Earth are present. If including other planets, the situation would become more complicated, but more details should be added to the question to answering it).
The issue involves the notion of inertial frame. The question may be paraphrased as follows:
Is it possible to fix an inertial reference frame where the Sun (the Earth) is viewed rotating around the Earth (respectively the Sun)?
Both possibilities are actually false. However, as the mass of the Sun is hugely grater than the one of the Earth, the centre of mass of the system which, in view of dynamical laws stays at rest in an inertial frame, is very close to the sun.
The fact that the rest frame of the Earth is not an inertial one implies that the motion of bodies described from an observers at rest with the Earth needs apparent forces to be dynamically explained. For instance, these forces do not verify the action-reaction principle and, in general they have no material cause as, instead, real forces have. So answering that question involves some nontrivial theoretical ideas.
Saying the sun rotates around the earth is equally valid to saying the earth rotates around the sun, or any more cumbersome viewpoint. Any frame of reference is equally valid.
However, if you are to calculate and predict the motions of the planets, you are far better off by using the heliocentric frame, because in the geocentric one you will have planets moving backwards from time to time.
pfnuesel
  • 1,996
-1
What about the stars? Do they also rotate around the earth? I think they would have to, otherwise you need the earth rotating, so that the stars appear to move round the earth. If so we are back to the old pre copernican view of the earth being a special body in the universe.
Dr Chuck
  • 1,310
