I am not sure (!), but I think in the next way.
First, consider a bead sliding along a rod without a friction in a inertial frame $Oxyz$. The rod rotates around axis $Oz$ with given function for angular velocity:
$$\omega = \omega(t)$$
Let write Newton's equation of motion for the bead in a frame $Ox'y'z'$ which rotates with the rod ($Ox'$ is parallel to the rod, $z=z'$), using formulas for inertial forces:
$$m\textbf{a}'=\boldsymbol N+m[\textbf{r}',\frac{d\boldsymbol{\omega}}{dt}]+2m[\boldsymbol{v}',\boldsymbol{\omega}]+m[\boldsymbol{\omega},[\boldsymbol{r}',\boldsymbol{\omega}]]=\boldsymbol N+\boldsymbol F_{Euler}+\boldsymbol F_{Coriolis}+\boldsymbol F_{centrifugal}$$
$$\boldsymbol{v}'=\dot{\boldsymbol{r}}',\boldsymbol a'=\ddot{\boldsymbol{r}}',\boldsymbol{r}'=(x',y',z')$$
A force $\boldsymbol N$ is a total (unknown) force of reaction from the rod to the bead. Without friction the force $\boldsymbol N$ is orthogonal to $\boldsymbol r'$. The bead is sliding along the rod so:
$$\boldsymbol r'=(x',0,0)$$
$$\boldsymbol N=(0,N_{y'},0)$$
Let $\omega(t)=const$, then $\boldsymbol F_{Euler}=0$. After all ($\boldsymbol F_{Coriolis}$ is also orthogonal to $\boldsymbol r'$) Newton's equation of motion gives a system of equations:
$$\begin{cases}\ddot x'=m\omega^2x'\\0=N_{y'}-2m\dot x'\omega\end{cases}$$
So when $\omega=const$ the reaction force $\boldsymbol N$ is just opposite to Coriolis force (from $Ox'y'z'$) and $\boldsymbol N= \boldsymbol N(v_r(t),\omega)$ in both $Oxyz$ and $Ox'y'z'$ frames, where $v_r(t)$ is a radial velocity of the bead.
Secondary, consider a planet which rotates around a star by circular orbit with a constant angular velocity in inertial frame $Oxyz$. A using of the rotated frame $Ox'y'z'$ gives us null values for Euler and Coriolis forces. In this case only centrifugal is here. And centrifugal force just is opposite to Newton Gravity force.
$$\boldsymbol r'(t)=(x'(t),0,0)=(R,0,0)=const$$
$$m\ddot x'=-GmM/{x'}^2+F^{centrifugal}_{x'}=0$$
where $R$ is the orbit radius. Thus
$$-GmM/{x'}^2+m{\omega}^2x'=0$$
In the case of an elliptic orbit centrifugal force isn't equal to Gravity force and the radius $R=R(t)=x'(t)$ is changed. The both Euler and Coriolis forces are not null, still orthogonal to radius-vector
$$\boldsymbol r'(t)=(x'(t),0,0)=(R(t),0,0)$$
$$\boldsymbol F^{Euler}=(0,F^{Euler}_{y'},0)$$
$$\boldsymbol F^{Coriolis}=(0,F^{Coriolis}_{y'},0)$$
and their sum must be zero
$$F^{Euler}_{y'}+F^{Coriolis}_{y'}=0$$
Probably the last formula gives an equation for radial velocity, tangential velocity and distance for the planet to the star
$$-mx'\dot\omega+2m\dot x'\omega=0$$
$$v_r=\dot x',v_\tau=\omega x',\dot\omega=\frac{d}{dt}(v_\tau/x')$$
