Is the acceleration of a free-falling observer at the Schwarzschild radius of a black hole the same regardless of the numerical value of the radius (i.e. outside of a black hole, is the acceleration of the free-falling observer only a function of his distance from the Schwarzschild radius)?
Is the acceleration at the event horizon of a black hole independent of the magnitude of its radius?
I'm going to take my life in my hands and disagree with Jerry (though actually we disagree only in terminology and not about the physics).
As with all things, the value of the acceleration for a freely falling observer depends on who you ask i.e. the figure you get depends on the coordinates you choose. There are three obvious observers you might consider:
- the freely falling observer
- the Schwarzschild observer at infinity
- a shell observer hovering at a fixed distance from the horizon
And of course there's the four acceleration, which is coordinate independant but isn't directly observed by anyone.
The case of the freely falling observer is easy because the acceleration they measure is zero, otherwise they wouldn't be falling freely.
The case of the Schwarzschild observer is also easy because the acceleration (and velocity) of the falling object asymptotically approaches zero as the object approaches the black hole.
The last case was analysed in twistor59's answer to What is the weight equation through general relativity?. The acceleration of the falling object measured by a shell observer is:
$$ a = \frac{GM}{r^2}\frac{1}{\sqrt{1-\frac{2GM}{c^2r}}} $$
and this goes to infinity at the event horizon.
So for all three observers the acceleration at the event horizon is independant of the mass/radius of the black hole.
However the four acceleration is given by (this is also in twistor59's answer):
$$ \mathbf{a} = (0, \frac{GM}{r^2}, 0, 0) $$
so for the freely falling observer at the event horizon:
$$ \frac{d^2r}{dt^2} = \frac{GM}{r_s^2} $$
which does depend on the black hole mass/radius. This is presumably the point in Jerry's answer.
- 367,598
No. The schwarzschild radius is located at $r_{S} = \frac{2GM}{c^{2}}$, and the 3-acceleration at this point (by one of physics's weird coincidences, this is identical to the newtonian expression) is given by the surface gravity $\kappa = \frac{GM}{r^{2}}$. Combining these two formulae, we find that $\kappa \propto \frac{1}{r_{S}}$, so the surface gravity depends on the schwarzschild radius.
- 42,237
