I know the derivation of Hubble time goes something like this (I am an a-level student so this may not be the actual derivation): Two galaxy that is moving away from each other at speed v are now D distance apart assuming the time when they where together is t=0 i.e. at the Big Bang the time since the Big Bang is given by $$T= \frac{D}{V}$$ $$V=\frac{D}{T}$$ Hubble's law is given by $$V=HD$$ therefore subbing the first expression into the latter gives $$\frac{1}{T}=H$$ and therefore $$T=\frac{1}{H}$$ The thing I do not understand is if we are assuming the rate of expansion is constant (as is required for this) why does that mean we can use $$t=\frac{d}{v}$$ Because as the galaxies get further apart together the space between them gets more and more hence they will move away from each other faster the further the are apart. This equation needs v to be constant which is not the case. Please can someone explain?
In the linked qestion they use the formula t=d/v just saying it is a linear extrapolation. This does not help me with my qestion as i can still not understand why this can be used as it assumes v is constant (i think) which it would not be. I am looking for this to be explained in more detail then the linked question.
In Hubble's mind, the universe was a static frame of reference. You can define an absolute rest frame, no need for all this badabada relativity stuff. In this frame, galaxies are moving in straight lines at constant speeds.
Now, what I think is confusing you is the value of $H$. As you have correctly derived, in this simplified model of the universe, $H=\frac{1}{t}$: the Hubble parameter is changing over time! We talk of the Hubble constant because Hubble's original data reached only 2 Mpc away, or 6.5 millions light years, that is a tiny fraction of the total age. So, even for the furthest galaxy he could observe, that was 6.5 million years old, the universe was pretty much as it is here today.
Hubble's data
You can see in this other question more details about the evolution of this parameters over time.
Davidmh
  • 2,168
