If it is true that an electron can be anywhere in the cosmos at any given time, then is it even theoretically possible that there is only one electron, instead of multiple electrons in the cosmos? If it isn't, I'd appreciate it if someone could point out where I may have misunderstood something as far as the fundamental properties of electrons are concerned.
Reid
  • 78
The idea that there could be just one electron originated when John Wheeler pointed out that a positron is the same as an electron moving backwards in time. All the electrons and positrons could be a single electron zigzagging backwards and forwards in time.
However this idea preceded the development of quantum electrodynamics, and QED completely changed the way we think about electrons. In QED there is an electron quantum field that permeates all of spacetime, and electrons are just excitations in this field. If we add a quantum of energy to the electron field it appears as a particle, that is an electron. Add a second quantum of energy and we have two electrons, and so on. Likewise, take a quantum of energy out of the field and an electron disappears.
This process allows electrons, and other particles, to be created and destroyed. For example every time a carbon 14 nucleus decays it creates an electron (and an anti-neutrino that is required to conserve lepton number) and the number of electrons in the universe increases by one. Conversely every time a magnesium 23 nucleus decays it creates a positron, and that positron can annihilate an electron and reduce the number of electrons in the universe by one.
So the fundamental object is now the electron quantum field rather than the electrons, which are just excitations in it. It no longer makes sense to argue there might be just a single electron, because the number of electrons is not a conserved quantity.
John Rennie
  • 367,598
No it is not a true statement. The true quantum mechanical statement is that
there exists a probability that an electron can be anywhere in the cosmos at any given time
This probability is infinitesimally small, and thus the probability that atoms could evolve is practically zero. So it is not even theoretically possible . Your misunderstanding comes from ignoring probabilities coming from the quantum mechanical basic framework.
anna v
  • 236,935
It is improbable that there is only 1 electron since there are many protons that require several electrons to neutralize the charge on the molecules.
LDC3
  • 3,827
"Only one electron" in the sense of "only one electron-positron worldline" weaving a tapestry throughout the universe is a hard no. Why? Because of this: $$W^- → e + \bar{ν_e}.$$ The electron-positron worldline is broken.
That totally destroys the narrative of there being only one electron-positron worldline weaving a tapestry in the entire universe. The only way you can advance the "there is only one" narrative is to throw neutrinos and anti-neutrinos into the mix and say there is only one electron/positron/neutrino/anti-neutrino.
But, then, you run into the second issue: neutrino-oscillation. Neutrinos change flavors in mid-route (Solar Neutrino Problem), ultimately because the neutrino eigenstates for W interaction are not energy-mass eigenstates. In turn, the different neutrino flavors are tied to the different leptons $μ$ and $τ$. Now, you're forced to push the narrative even further and say that there is only one lepton/anti-lepton and it's a total shape-shifter.
But, then you run into this: $$Z → e + \bar{e} → γ + γ.$$ The electron-positron worldline, here, is isolated from all the other lepton worldline segments.
So, even if you identify all leptons, the "there's only one [anti-]lepton (and it's a shape-shifter)" narrative is still broken; because now you have multiple disconnected [anti-]lepton worldlines weaving tapestries, not just one.
NinjaDarth
  • 2,850
  • 13
