I've recently been working on relative equilibria for some systems of particles. (ie. studying equilibrium solutions in a rotating frame. Saturn's rings for example.) This has evolved into some classical notions of atomic physics and questions of stability for Coulomb interactions there. Entertain for a few moments a classical(planetary) model for the atom. Take an isolated hydrogen atom for example. It seems to me that the $q\left(v\times B\right)$ term of the Lorentz force provides an intrinsic stabilization for the two particle system. Naively play the right hand rule game with the system and you'll see. If we assume that the electron is in a classical orbit and not radiating, then could we establish the stability of atoms with the Lorentz force? The non-radiating electron is a topic of its own and appears to be far from solved. For example, if you would like to make the statement that accelerating charges radiate, therefore...... Try to go one step further and show why this must be true in general and you imediately run into difficulties. Gyro-stabilization might be a relevant topic here.
Order of Magnitude investigation:
\begin{align} &\text{Proton Charge:}\qquad&q &\approx 1.602\times 10^{-19}\: C\\[2mm] &\text{Permeability of free space:}\qquad &\mu_0 &\approx 4\pi\times10^{-7}\frac{volt\cdot s}{amp\cdot m}\\[2mm] &\text{Permitivity of free space:}\qquad &\epsilon_0 &\approx 8.854\times10^{-12}\frac{farad}{m}\\[2mm] &\text{Electron Speed: }\qquad &v &= \alpha c\approx c/137 \approx 2.19\times10^6\frac{m}{s}\\[2mm] &\text{Electron Radius:(Bohr) }\qquad &r & = \frac{\hbar}{m_ec\alpha}\approx 5.29\times10^{-11}m\\[2mm] \end{align}
Maximum Fields(Im thinking of the fields generated by the electron in a linear approximation for an infinitesimal section of the circular orbit:
\begin{align} \text{Biot - Savart}\qquad{\bf B}_{\text{max}} &= \frac{\mu_0 q v}{4\pi r^2}&\approx& 12.537\:\text{T}\\[2mm] \text{Coloumb}\qquad{\bf E}_{\text{max}} &= \frac{q}{4\pi\epsilon_0 r^2}&\approx& 5.145\times 10^{11}\frac{N}{C} \end{align}
With Force ratio:
\begin{align} \frac{q(v\times{\bf B})_{max}}{q{\bf E}_{max}} =\frac{\frac{\mu_0 q^2 v^2}{4\pi r^2}}{\frac{q^2}{4\pi\epsilon_0 r^2}} = v^2\mu_0\epsilon_0 = \frac{v^2}{c^2}\approx\frac{(2.19\times10^6)^2}{(3\times10^8)^2}\approx 5.329\times10^{-5} \end{align}
This shows the magnetic force is 5 orders of magnitude smaller than the electrostatic force for this crude model of the ground state hydrogen. Not sure what this conclusively says about the internal dynamics but at least I think I can foresee some problems with this force stabilizing the system.
A colleague of mine who does work with NMR(nuclear magnetic resonance) informed me that the magnetic fields they work with in the lab are on the order of 3$T$ and that they do not observe the large fields I am envisoning in practice. The concept he quoted as the reasoning behind this was "orbital quenching". This appears to be a sort of averaging to zero of this field. However, it was also stated that the magnetic field that I am interested in can be measured in beam type experiments.
JEM
  • 176
Could we establish the stability of atoms following this line of reasoning?
Magnetic forces do not seem to be enough if the fields are retarded (most natural assumption), for the system proton+electron will radiate some energy away and cannot be stable in the Newtonian sense. Background radiation or non-electromagnetic forces are needed to make the system stable. If the fields are half-retarded, half-advanced, stable orbits were reported to be possible, cf.
J. Frenkel, Zur Elektrodynamik punktfoermiger Elektronen, Zeits. f. Phys., 32, (1925), p. 518-534. | http://dx.doi.org/10.1007/BF01331692
and
L. Page, Advanced Potentials and their Application to Atomic Models, Phys. Rev. 24, 296 (1924) | http://journals.aps.org/pr/abstract/10.1103/PhysRev.24.296
-1
"The non-radiating electron is a topic of its own and appears to be far from solved.". That's an interesting statement, since there is ample evidence, that there are no such things as "non-radiating electrons".
The only thing that "exists" in nature at that scale is a quantum field, one solution of which are electrons. Under certain circumstances (when energy levels stay below the rest energy of the next higher excitations i.e. muons), electrons and photons can be treated using a simplified theoretical framework called quantum electrodynamics (QED). The problem of atomic stability is completely resolved within that framework, even though other (numerical) problems still remain.
CuriousOne
  • 16,486
