17
Previously, I have calculated energy spectrum for 3D isotropic turbulent flow data which is equally spaced in all three directions and then to compute the energy spectrum, one performs Fourier transform and then accumulates energy located in different wavenumber bins and then gets the ($k^{−5/3}$) slope and it all works fine.
Now if I want to extend the same for an anisotropic case like turbulent boundary layer case, how should I modify the technique? I cannot take a Fourier transform in the wall normal direction anymore and I am not sure how to compute the energy spectrum as such. There is no problem if I compute the spectrum for streamwise and spanwise plane since they are both defined using Fourier basis.
So my question is two-fold:
  1. How do we compute energy spectrum for a 3D turbulent boundary layer?
  2. If we cannot compute it for a 3D case i.e. if the argument is valid only for a 2D planar cut at various wall normal locations, then how do we define a scale for turbulent boundary layer cases, particularly along wall normal direction?
Sidhha
  • 279
Usually, near-wall turbulence is thought about using the Law of the Wall where the distance from the wall enforces a maximum length scale for isotropic motion.
