12
I know that we can make water solid with high pressure, so I think water will be solid in the deep ocean?
If that is true, the depth of the ocean would be limited because water will become ice? Anyone know that maximum depth?
damphat
  • 231
You are mistaken. Actually, you can melt ice by applying pressure. This is why ice is so slippery; when you step on a frozen lake, you are melting the very first layer of water, and thus creating a very good instant lubricant for you to slide on. It is a common knowledge false fact, see comments.
Ok, granted, at very high pressures water does become solid. From the phase diagram, to get solid at around 0 °C you need around 650 MPa. How much is that? Pressure depends with depth as:
$$P = \rho g h$$
Assuming constant density, you need a column of water of $66\ \mathrm{km}$ for ice to be formed. That is about six times the depth of Challenger Deep, in Mariana trench.
So the answer is no – on Earth. You will not find enormous amounts of more or less pure liquid water anywhere else in the Solar System, but if you are happy with hydrogen, helium, and other gases, you may find it around Jupiter's core. Definitely, liquid H and He.
When water is mixed with other elements, the phase diagram is perturbed. For example, salt in the sea at atmospheric pressure lowers the freezing point about a couple of degrees (depending on the concentration). If water is mixed with hydrogen, helium, methane, and company as in a gas giant, the diagram will be drastically changed, so more detailed computations would be needed.
Davidmh
  • 2,168
In principle, at sufficiently high pressure water does turn into a solid, as can be seen from the phase diagram of water below (image source). This however requires pressures of about $10$G Pa=$10^{10}$ Pa, which is about $10^5$ times bigger than the atmospheric pressure ($\approx 10^5$ Pa = 1 bar). The pressure at the bottom of Mariana Trench is about a thousand times the atmospheric pressure - that is one would need a 100 times higher pressure for turning water into solid.
Roger V.
  • 68,984
As stated in order for water to become solid due to pressure it would need pressures 100 times greater than those found even at the deepest of ocean depths on Earth. However, it is believed that it is almost a certainty that elsewhere in our galaxy there are large water-covered worlds with oceans deep enough to become solid.
