27
Let me first say that I'm a layman who's trying to understand group theory and gauge theory, so excuse me if my question doesn't make sense.
Before symmetry breaking, the Electroweak force has 4 degrees of freedom ($B^0$, $W^1$, $W^2$, and $W^3$ right?) and after symmetry breaking, we are left with the weak $SU(2)$ bosons ($W^+$, $W^-$, $Z$) and the photon. Why, then, is the symmetry group before Electroweak symmetry breaking $SU(2) \times U(1)$ and not just $U(2)$ (Since a Unitary group of $n$ dimension contains $n^2$ degrees of freedom?) What am I missing?
Actually we have the following Lie algebra isomorphism
$$\tag{1}u(2)~\cong~ u(1)\oplus su(2),$$
and there exists the following Lie group isomorphism
$$\tag{2} U(2)~\cong~[U(1)\times SU(2)]/\mathbb{Z}_2 ,$$
cf. e.g. this Phys.SE post.
In other words, there is a two-to-one map from $U(1)\times SU(2)$ to $U(2)$.
So in that sense the Glashow-Salam-Weinberg (GSW) $U(1)\times SU(2)$ model already contains a $U(2)$ gauge group!
Of course, the various matter and gauge fields transform naturally in the weak hypercharge and weak isospin language, i.e., under $U(1)\times SU(2)$.
On the other hand, if we construct the GSW electroweak model with the smaller gauge group $U(2)$ [rather than the full $U(1)\times SU(2)$ gauge group], then a matter field transforming in a (hypercharge,isospin) irrep $(Y,I)$ may become multi-valued, depending on the fractional value of the hypercharge $Y$. This does not happen for the standard model field content, cf. this Phys.SE post. So in that sense the electroweak gauge group is $U(2)$ [via the Lie group isomorphism (2)].
The correct electroweak gauge group is $SU(2)_L \times U(1)_Y$ where $Y$ denotes the weak hypercharge. After the Higgs field spontaneously breaks this exact symmetry, third generator of $SU(2)_L$ (weak isospin) and weak hypercharge combine to give the remaining unbroken $U(1)_{em}$.
Gauge bosons and fermions fall under different representations of this gauge group and transform non-trivially under the action of the group. For example $W_{1,2,3}$ transforms as a triplet under $SU(2)_L$. Left handed fermions transform as $SU(2)_L$ doublets. This simply means that under the action of a symmetry transformation, components of each representation are mixed in a special way depending on the representation of the gauge group. So quantum numbers of our fields determine how they transform and interact with each other. For the electroweak sector of the Standard Model, the correct properties are obtained with the gauge group $SU(2)_L \times U(1)_Y$ and not with $U(2)$.
Having said that in grand unified theories one starts with a larger gauge group that contains the SM gauge group and try to break it down to the SM gauge group.
