So I was eating a plate of food one day and thought of entropy. As I understand the definition of entropy, it is the logarithm of the number of arrangements or states the object in question can be in, where the object is composed of N number of particles/food particles. Please edit my definition if this is wrong.
So, I'm eating a plate of food, and I have diced up chicken, rice and vegetables on the plate all mixed together. I thought, the current system I have, the food is arranged in a state that is of high entropy because this arrangement is common compared to the number of other more rare arrangements, ie 1/3 chicken, 1/3 vegetables, and 1/3 rice in an pie chart looking fashion.
I like to eat neatly, and naturally, I've conditioned myself to pick up the food with my fork such that while I pick up chicken and rice, rice falls off one side of my fork in a certain direction. As I eat, I sometimes end up with a more neater, higher entropy state than what I began with. I didn't spend extra energy making it neater, I just pick up my food in strategic ways because that's how I normally eat.
My question is, how is this possible? I end up with a more neat arrangement on my plate than I started with. I know food gets eaten, so the number of particles decreases with time. So because the number of food particles decreases, the number of arrangements also decrease!! Can someone continue my chain of thought and correct me if I'm wrong? What do I need to think of next? Why is it that it appears that the entropy of my plate of food seems to lower with time?
6 Answers6
QEntanglement, the answer is simple.
Your plate of food is not a closed system. For the system to close you need the plate, and the whole of you. with your chewing and digestion. Entropy increases in closed systems. Otherwise, think about it, could DNA exist, and the whole caboodle of organic life? We are factories that defy entropy, until we die, because we are open systems.
In inorganic systems, crystals crystallizing out of a solution are highly ordered, but they are not a closed system. When the solution is considered to close the system, entropy increases.
anna v
  • 236,935
Entropy is the measure of the disorder or randomness in a system. In other words, if you drop a box of matches on the floor, the matches will fall all over the place, which is an increase in entropy. For an example of decreased entropy, if you build a house you are making order, not chaos, so the entropy-the disorder of a system-is decreased. I hope this was an understandable explanation. :)
Jasi Q
First: Look at the good answer by anna.
One side note: The second law of thermodynamics (increase of entropy) is a stochastical law. That is: It is like this 99.99…% of the time/system you look at. But there might be instances, where it is decreasing for some short time (but very likely will increase shortly after to the values observed at any time before).
Background: Poincaré recurrence theorem basicly states, that a closed system will get back to a point very close to its current state at a later time. This time might be extremely long (so long, you can basicly summarize it as "never"). Zermelo noted (not the best link, but I did not find a better one) that this contradicts increase in entropy. Boltzmann had a lengthy answer paper in 1896 (doi:10.1002/andp.18962930414, it's in german) explaining this and explaining that this is a stochastical thing.
Elrond
  • 101
Your question is a more complicated version of "Maxwell's demon". When you try to decrease entropy of an open system from the outside, your memory device needed for such control will necessarily (thermodynamically speaking) increase the total entropy of the universe. You should look up "Maxwell's demon". By the way, if you recognize a pattern of food and you have a strategy in mind. You most likely are net increasing entropy of the universe to different degrees no matter you choose to execute your plan or not.
Bohan Xu
  • 728
You did spend the energy to make it neater, by eating in a certain way. What you mean is that it was not your conscious intention and/or the goal, but that's philosophical rather than physical difference.
Remark: Note that entropy is not as simple as it seems, and there are different ways to define it with different properties: Is information entropy the same as thermodynamic entropy? In particular, in the OP it is first defined as Boltzmann entropy ($S=k_B\log N$) but then you essentially treat it as a Shannon entropy.
Roger V.
  • 68,984
-2
I was thinking about entropy and food the other day too. One of my friends posted something about some nutter that insisted he has never been I’ll because he eats raw chicken and pork. My brain decided to to entertain the notion and came up with this: Eating foods in their natural state- or high entropy- leads to animalistic development of the brain and its immune system. But by lowering the entropy by combining ingredients and applying energy- cooking- you create complex fuel for a complex brain to develop.
