68
Suppose in the milliseconds after the big bang the cosmic egg had aquired some large angular momentum. As it expanded, keeping the momentum constant (not external forces) the rate of rotation would have slowed down, but it would never reach zero.
What implications would that have to measurments to distant supernova and CMB radiation? Do we have any experimental data that definitely rules out such as scenario? And to what confidence level?
Edit A Recent Article suggests that the universe might indeed be spinning as a whole. Anyone care to poke holes at it?
Edit 2 Even more Recent Article places limits on possible rotation.
Edit 3 Apparently Gödel pondered the same question ( https://www.space.com/rotating-universe-would-permit-time-travel)
John Alexiou
  • 40,139
6 Answers6
46
If you believe wholeheartedly in Mach's principle, then there is no way to test empirically for rotation of the universe as a whole, since there is nothing else for it to be rotating relative to. However, general relativity is not very Machian, and it offers a variety of ways in which an observer inside a sealed laboratory can detect whether the lab is rotating. For example, she can observe the motion of a gyroscope, or measure whether the Sagnac effect is zero. There are alternative theories of gravity, such as Brans-Dicke gravity, that are more Machian than GR,[Brans 1961] and in these theories there is probably no meaningful sense in which the universe could rotate. However, solar-system tests[Bertotti 2003] rule out any significant deviations from GR of the type predicted by Brans-Dicke gravity, so that it appears that the universe really is as non-Machian as GR says it is.
It is therefore possible according to general relativity to have cosmologies in which the universe is rotating. Historically, one of the earliest cosmological solutions to the Einstein field equations to be discovered was the Gödel metric, which rotates and has closed timelike curves. If we lived in a rotating universe such Gödel's example, the rate of rotation would have to be expressed in terms of angular velocity, not angular momentum. Angular velocity is what is measured by a gyroscope or the Sagnac effect, and GR doesn't even have a definition of angular momentum that applies to cosmological spacetimes.
A rotating universe does not have to have a center of rotation, and it can be homogeneous. In other words, we could determine a direction in the sky and say that the universe was rotating counterclockwise at a certain rate about the line connecting us to that point on the celestial sphere. However, aliens living somewhere else in the universe could do the same thing. Their line would be parallel to ours, but there would be no way to tell whether one such line was the real center of rotation.
To find out whether the universe is rotating, in principle the most straightforward test is to watch the motion of a gyroscope relative to the distant galaxies. If it rotates at an angular velocity -ω relative to them, then the universe is rotating at angular velocity ω. In practice, we do not have mechanical gyroscopes with small enough random and systematic errors to put a very low limit on ω. However, we can use the entire solar system as a kind of gyroscope. Solar-system observations put a model-independent upper limit of 10^-7 radians/year on the rotation,[Clemence 1957] which is an order of magnitude too lax to rule out the Gödel metric.
A rotating universe must have a certain axis of rotation, so it must have a particular type of anisotropy that picks out a certain preferred direction. We can therefore look at the cosmic microwave background and see whether its anisotropy contains a preferred axis.[Collins 1973] Such observations impose a limit that is tighter than provided by solar-system measurements (perhaps 10^-9 rad/yr[Su 2009] or 10^-15 rad/yr[Barrow 1985]), but such limits are model-dependent.
Because all of the present observation are consistent with zero rotational velocity, it is not possible to attribute any prominent cosmological role to rotation. Centrifugal forces cannot contribute significantly to cosmological expansion, or to the way your head feels when you're hung over.
Brans and Dicke, "Mach's principle and a relativistic theory of gravitation," Phys. Rev. 124 (1961) 925, http://loyno.edu/~brans/ST-history/
Bertotti, Iess, and Tortora, "A test of general relativity using radio links with the Cassini spacecraft," Nature 425 (2003) 374
Clemence, "Astronomical time," Rev. Mod. Phys. Vol. 29 (1957) 2
Collins and Hawking, "The rotation and distortion of the universe," Mon. Not. R. Astr. Soc. 162 (1973) 307
Hawking, "On the rotation of the universe," Mon. Not. R. Astr. Soc. 142 (1969) 529
Barrow, Juszkiewicz, and Sonoda, "Universal rotation: how large can it be?," Mon. Not. R. Astr. Soc. 213 (1985) 917, http://adsabs.harvard.edu/full/1985MNRAS.213..917B
Su and Chu, "Is the universe rotating?," 2009, http://arxiv.org/abs/0902.4575
[This is a physicsforums FAQ entry that I wrote with input from users George Jones, jim mcnamara, marcus, PAllen, tiny-tim, and vela.]
12
I think in that case the universe will be homogeneous but not isotropic. Such geometries were classified by Bianchi, and they have parameters that are constrained be experiment (not my area of expertise, so I am not sure to what degree). As far as I know, there is no indication that angular momentum is needed to explain any cosmological observation.
Incidentally, I don't think general relativity (or any other current theory) obeys Mach's principal, as usually phrased it requires highly non-local effects. Frame dragging may be in the spirit of Mach's principle, but it follows from perfectly local interactions as encoded in GR.
I am not sure about the Lense-Thirring effect in this case, but it is definitely true that a global rotation would be described by one of the Bianchi homogeneous but anisotropic (not isotropic) models as mentioned by Moshe. For beautiful pictures as to how the Cosmic Microwave Background anisotropy sky would look in those models, see the paper by Andrew Pontzen for example (Pontzen 2009).
Using the current CMB data, especially from the WMAP experiment, one can impose upper bounds on (and perhaps some day, detections of) those Bianchi models. This work goes at least as far back as Ted Bunn and collaborators' paper (Bunn, Fereira & Silk 1996)
Mach's principle says that inertia arises from the mass of everything else in the universe, and so if the universe were rotating, it would be dragging us around in a circle with it, and because of that we wouldn't notice it. This frame-dragging actually happens, and is called the Lense-Thirring effect. If you were inside a massive rotating sphere, your frame of reference would be rotating with respect the rest of the universe outside the massive rotating sphere. However, I'm not sure whether the Lense-Thirring effect actually implies Mach's principle. Maybe somebody who knows more could help.
Peter Shor
  • 11,536
If you say that universe is rotating "as a whole" you'd have to define a rotation axis. A rotation axis would cause some problems, like violating a homogeneous and isotropic universe, as proposed by cosmic inflation model.
By the way, you can not say that the universe is rotating at the same angular speed everywhere with respect to the rotation axis. This would cause faster than light linear velocities, although I simply used classical mechanics to calculate, maybe a relativistic model is possible.
The existence of such an angular momentum might have some implications though. For example, one could say, if the theory "Big Bounce"(http://en.wikipedia.org/wiki/Big_bounce) is correct, one could say the origin of the entire universe is a black hole with an angular momentum, that is, a rotating black hole with possibly no electrical charge.
Cem
  • 1,708
-2
Hoyle and Narlikar have also shown that rotation in fact decays for an expanding universe - which could potentially explain why if rotation exists, it appears to be very very slow (see Hawking's own remarks on this). It also explains why there would be no discernible axis of rotation. Dark flow could be a residual primordial spin to the universe (something I speculated a while back). Rotation also requires energy - there could have been a bulk-to-rotation exchange of energy which may explain the vacuum energy problem (bit of a reach but I found it hard not to mention it). Obviously a rotating universe early on would play a significant role in the expansion of a universe due to an internal centrifugal force. The universe appears to have got large enough not to be hindered by the gravitational binding forces inside of it. The following link https://gyroverse.quora.com/ is my own work, but gives a reasonable jist for an expanding universe.
