13
Please forgive me if I'm wrong, as I have no formal physics training (apart from some in high school and personal reading), but there's something about Heisenberg's Uncertainty Principle that strikes me as quite obvious, and I find it strange that nobody thought about it before quantum mechanics development began, and still most people and texts explain it in quantum mechanics terms (such as citing wave/particle dualism, or the observer effect)... while actually it should appear blatantly obvious in classical mechanics too, at least regarding the position and momentum variables, due to the very definition of speed.
As everyone knows, the speed of an object is the variation of its position over an interval of time; in order to measure an object's speed, you need at least two measurements of its position at different times, and as much as you can minimize this time interval, this would always create an uncertainty on the object's position; even if the object was exactly in the same place at both times, and even if the time was a single nanosecond, this still wouldn't guarantee its speed is exactly zero, as it could have moved in the meantime.
If you, on the contrary, reduce the time interval to exactly zero and only measure the object's position at a specific time, you will know very precisely where the object is, but you will never be able to know where it came from and where it's going to, thus you will have no information at all about its speed.
So, shouldn't the inability to exactly measure the position and speed (and thus the momentum) of an object derive directly from the very definition of speed?
This line of reasoning could also be generalized to any couple of variables of which one is defined as a variation of the other over time; thus, the general principle should be:
You can't misure with complete accuracy both $x$ and $\frac{\Delta x}{\Delta t}$
For any possible two points in time, there will always be a (however small) time interval between them, and during that interval the value of $x$ could have changed in any way that the two consecutive measurements couldn't possibly show. Thus, there will always be a (however low) uncertainty for every physical quantity if you try to misure both its value and its variation over time. This is what should have been obvious from the beginning even in classical mechanics, yet nobody seem to have tought about it until the same conclusion was reached in quantum mechanics, for completely different reasons...
Massimo
  • 239
7 Answers7
11
The uncertainty principle says something a deeper than "it is impossible to measure both position and momentum to arbitrary accuracy". It says
1) The accuracy is precisely limited by $\Delta x \Delta p > \hbar/2$.
2) In fact, this is not a limit of our measuring procedure, but a limit of reality. If something has well-defined position, it does not have a well defined momentum, and vice-versa. In other words, it's not that we can't precisely measure the exact momentum; if an object has a well-defined position, it does not have a well-defined momentum.
Your argument doesn't really get at the real content of the uncertainty relationship, which is that there is no such thing as a particle with well-defined momentum and position.
Jahan Claes
  • 8,388
The uncertainty principle doesn't say anything about simultaneous measurements of a particle - that's just a myth which originated from Heisenberg's interpretation of it.
Let us first describe the basis of quantum physics and let's start with the most innocent looking object: the quantum state. We can see a quantum state as a prescription to prepare a system. It's a number of steps how to prepare your system (e.g. how to build a one-electron source, how to set it up in a vacuum, how to install magnetic fields and apply them to produce an electron with specific spin direction). In the literature, you'll hear something like "this electron is in the state..." - this is just an extreme short cut for saying: in our theory, we can define objects such as electrons and they have properties and we have an experimental procedure that produces results that seems to work exactly as we would predict if it were an electron of our theory.
The second step is a measurement. From classical physics, it is pretty clear what a position measurement is and a momentum measurement is only slightly more difficult. In quantum physics, we already have to be much more careful, but let's suppose we know what it means to measure position and momentum (for position, we can for example take a number of detectors in an array and when one detector makes "click", this tells us the position of the instance of the state we created). This implies that we have another set of rules that gives us some classical output to read of a screen and that we call "momentum" of the state or "position".
Now, suppose we want to have a very special state that is as localized as possible, i.e.: we prepare a state (or better: we perform the procedure defined by the state) over and over and each time we measure the position. Like this, we get a distribution of the positions - if our preparation is not very accurate, the variance of that distribution will be large, if it is quite accurate, it will be small. We go on and change the state (i.e. refine the procedure) such that ultimately, whenever we create an instance of the state and we measure its position, every time the same detector clicks. Let's assume we can achieve arbitrary accuracy, i.e. the detector is really small and it's really always the same detector that clicks.
And now, instead of measuring the position, let's measure the momentum of our perfectly localized state. What happens? We'll get some result, but when we redo the experiment, it'll be completely different. We do the preparation & measurement over and over again and the probability distribution for momentum we receive will have a huge variance.
Heisenberg's uncertainty relation tells us that regardless of what we do, this is the picture we must obtain. We can try to change the preparation procedure as much as we want and assuming we could work with arbitrary precision, we cannot define a procedure were both the position and the momentum density we obtain have a small variance.
This is contrary to classical mechanics: Let's suppose I want to do the experiment where I try to see whether two stones of different masses fall differently. Galileo supposedly did this in Pisa by throwing two stones from the tower. His "state" was: I take two stones and hold them directly next to each other. Then I let them fall. But this means that at the beginning of the experiment, he knew both the position (next to each other) and the velocity (zero) perfectly - otherwise the conclusion wouldn't make sense. Heisenberg's uncertainty relation tells us that this is not possible in quantum mechanics - it doesn't even really make sense to ask the question.
Martin
  • 15,837
In order to measure an object's speed, you need at least two measurements of its position at different times.
This is not the case. The radar guns used by police to determine if you are exceeding the speed limit do not use position measurements. They instead measure the frequency difference between the outgoing and reflected signals. No position measurements are required.
Conceptually, one could use a measurement from a radar gun to simultaneously determine position and velocity: Measure the frequency shift between the outgoing and incoming signals and measure the time difference between transmission and reception. The first measurement yields velocity, the second, position.
Shouldn't the Uncertainty Principle be intuitively obvious, at least when talking about the position and momentum of an object?
No, it's not. Classically, one could make measurement devices that simultaneously measure position and velocity to any desired degree of precision. I gave an example above. Even if two position measurements are used, simply making those position measurements ever more precise lets one use two position measurements closely-spaced in time to measure both position and velocity to any desired degree of precision. There are no limits to the precision of measurements of canonically conjugate variables in classical mechanics.
The uncertainty principle says that this is not possible. There are limits, specifically $\Delta x \Delta p>\hbar/2$. This is not just a limitation on measurement devices. It is much deeper than that. The uncertainty principle is a fundamental limitation of reality, as opposed to a minor constraint on measurement devices.
David Hammen
  • 42,721
  • 81
  • 129
No, not necessarily.
A police radar gun can be used to measure the speed of a object at a single point in time.
It can also be used to measure its position in space at the same time.
Using Heisenberg's Uncertainty Principle:
$$ \sigma_x \sigma_\rho \geq \frac{\hbar}{2} $$
Which leaves a minimum accuracy of speed of a one tonne car measured to $1~\text{nm}$ accuracy at $5 \times 10^{-29}~\text{ms}^{-1}$. So classically for all intents and purposes one can measure a car to an arbitrary accuracy of both position and momentum at any point in time without invoking HUP.
This is made even easier when you assume that the measurement of position does not affect its position or momentum, which classically is true for the car, so you can measure them separately in any order.
user288447
  • 1,954
"So, shouldn't the inability to exactly measure the position and speed (and thus the momentum) of an object derive directly from the very definition of speed?"
Yes, if you are talking about instantaneous speed. There is no speed at a point because the definition requires two points.
No, if you are talking about average speed, which unsurprisingly is what everyone means when they are talking about speed in the macroscopic regime.
gregsan
  • 4,403
No. You can not talk about the uncertainty principle without associating a wave to a particle according to the de Broigle hypothesis.
"A function (a wave) and its Fourier transform cannot both be sharply localized in time and frequency, respectively." A short pulse around moment $t_0$ appears like a vertical line on the screen of an oscilloscope but if you display its spectrum (calculated by the same oscilloscope if it is a smart one) you will remark that the spectrum covers a large part of the screen spreading over a broad range of frequencies.
If you do not associate a wave to a particle or to a macroscopic body the uncertainty principle does not make sense.
See also the following explanation:
Mathematically, in wave mechanics, the uncertainty relation between position and momentum arises because the expressions of the wavefunction in the two corresponding orthonormal bases in Hilbert space are Fourier transforms of one another (i.e., position and momentum are conjugate variables). A nonzero function and its Fourier transform cannot both be sharply localized. A similar tradeoff between the variances of Fourier conjugates arises in all systems underlain by Fourier analysis, for example in sound waves: A pure tone is a sharp spike at a single frequency, while its Fourier transform gives the shape of the sound wave in the time domain, which is a completely delocalized sine wave. In quantum mechanics, the two key points are that the position of the particle takes the form of a matter wave, and momentum is its Fourier conjugate, assured by the de Broglie relation p = ħk, where k is the wavenumber. Source
-1
Yes the argument that you can not measure the speed at single point is correct, but if you take a distance 'dx' and then measure the time 'dt', you will measure the momentum absolutely and position can be determined with the uncertainty of dx. Now you may divide dx by n and measure the time dt again you will get absolute momentum and even more precise position.
But how small you can go. classically you may make n tends to infinite and you will have no uncertainty in both momentum and position.
If you try to derive the uncertainty relation classically you can derive it but you can not define the lower limit, as soon as you apply the quantum considerations (wave particle duality) you can set the lower limit such that
$\Delta x$ $\Delta p$> $\hbar$/2.
hsinghal
  • 2,601
