This question concerns the following situation: I have some gas of identical particles and they are in a box which has been partitioned into two halves by a removable divider. Now the question is: If I remove the divider, why should the change in entropy be 0? The standard answer is given in the linked question. The main idea is that the particles are supposed to be considered indistinguishable. If you treat the particles this way, you find that there is no change in entropy when the partition is removed.
I understand this answer, and I suppose it should work for identical atoms, but you can easily imagine a situation where you have a collection of objects which are distinguishable, say some nanoparticles with differing numbers of constituent atoms.
Furthermore, you should be able to treat a gas of identical particles as classical distinguishable bodies, and still get the right answer from statistical mechanics. I would say this is a good check of understanding of statistical mechanics.
If this isn’t enough motivation to come up with an alternate resolution to the paradox, consider this paradox, which requires essentially the same resolution that the Gibbs paradox: Imagine two systems initially in thermal contact and in thermal equilibrium. Now suppose they are separated. Here we might think the entropy will decrease in this process because in the initial configuration the energy of both systems were allowed to change as long as their sum remained constant. After separation, the systems’ energies are fixed at some value. Clearly the set of final states is a subset of the set of initial states, so the entropy has decreased. This is the analogy of the Gibbs paradox where instead of the systems exchanging particle number, they are exchanging energy. I would expect it to have essentially the same resolution.
So my question is: Why should the change in entropy be zero, even in the particles are distinguishible?
