21
As we all know the speed of light is the limit at which energy/matter can travel through our universe.
My question being: is there a similar limit for acceleration? Is there a limit to how quickly we can speed something up and if so why is this the case?
Short question, not sure what else I can elaborate on! Thanks in advance!
Carterini
  • 401
7 Answers7
There are two answers:
  1. If the mass of the body is given, the limit is Caianiello's maximal acceleration, http://arxiv.org/abs/quant-ph/0407115 : $a_{\max}=2 m c^3/\hbar$
  2. If any mass value is allowed, the limit is the Planck acceleration, given by Plank length/Planck time^2.
As of today, there is no working theory which would put a fundamental limit on acceleration.
Specifically, Julian Fernandez and Arthur Suvorov commented on the tidal forces or relative acceleration in general relativity which can be infinite for example in the center of a black hole. However, note that this is not really an acceleration of a single point, as relativity says a particle does not accelerate in gravity but follows a geodesic - a space-time analogy of a straight line followed with "uniform" four-dimensional velocity.
Tidal forces just describe the phenomenon when geodesics at different points differ heavily causing a larger object to be squashed or ripped apart by the effective "force" of every part of it's body trying to follow a completely different geodesic.
In particle physics, as of now, we describe particle interactions as contact. In that sense, they transfer momentum (and thus velocity) instantaneously. It is obvious that in such a process acceleration has an infinite peak in the moment of interaction.
However, both theories, general relativity describing gravity and quantum field theory describing particle physics, are assumed not to be correct on arbitrary scales. Specifically the two mentioned cases, singularities in black holes and point-interaction, are expected to be modified when looking close enough. These scales which are conjectured to be "close enough" are called Planckian scales described by anna v. These are basically a combination of constants from relativity and quantum theory assembled to give quantities with dimension such as "length" or "time".
Nevertheless, even though we presume these cases of "infinite accelerations" to not be accurately described (physicists just don't like infinities), there is no wider, inevitable notion that there should be an upper limit on acceleration even in the new theories.
Void
  • 21,331
Acceleration is dv/dt
v is limited by the velocity of light.
delta(t) is limited by Planck time, in the sense that physics in smaller time intervals is not known
planck time~5.39106(32) × 10−44 s
One Planck time is the time it would take a photon traveling at the speed of light to cross a distance equal to one Planck length. Theoretically, this is the smallest time measurement that will ever be possible, roughly 10^−43 seconds. Within the framework of the laws of physics as we understand them today, for times less than one Planck time apart, we can neither measure nor detect any change. As of May 2010, the smallest time interval uncertainty in direct measurements is on the order of 12 attoseconds (1.2 × 10^−17 seconds), about 3.7 × 10^26 Planck times.
Substituting these numbers and assuming delta(v) is of order c ,10^8 meter/second, puts the limit of acceleration at order 10^52 meters/second**2.
So yes, there is a limit to measuring a difference in velocity to be attributed to acceleration.
anna v
  • 236,935
Assuming there are black holes with singularities, then the acceleration can be as a high as you want inside a black hole, the larger the closer you get to the singularity.
As far as I'm aware, there is no limit to the acceleration a particle (or anything else) can experience.
Why? Well, one may start looking at Newton's second law $F = ma$ and say, well, $a$ can be just as unbounded as $F$, right? Like Julian has said, tidal forces near black holes can become unbounded as you approach the singularity. Black holes are a general relativistic phenomenon though, so this equation is inadequate. Now when you enforce the postulates of relativity and assume $c < \infty$, relative acceleration is governed by the geodesic deviation equation:
$\frac {D^2 X^{\mu}} {dt^2} = R^{\mu}_{\nu \rho \sigma} T^{\nu} T^{\rho} X^{\sigma}$
where $T^{\mu} = \frac {\partial x^{\mu}} {\partial t}$. There is no apriori bound placed on how 'negative' the Riemann tensor is allowed to be; that is to say there are no mathematical results (assuming a $\it{really}$ generic space-time) that limit the behaviour of $R^{\mu}_{\alpha \beta \gamma}$, and hence the term on the LHS relating to acceleration.
However, with regards to the Heisenberg uncertainty principle, we must consider space-time to essentially be a discrete object, meaning we cannot infinitely divide up time and obtain a continuous limit (otherwise observations don't make sense). This in mind, no matter how small you make the time steps, we must limit the overall 4-velocity $v^{\mu}$ of the object to be bounded by $c$. So, acceleration must always be finite but can grow arbitrarily large, since we approximately have in a time-step $\delta t$: $v \approx a \delta t$.
Edit: What I really mean in this last paragraph is that it does not make sense to talk about motion in zero time. So, since $v < \infty$, and $\delta t >0$, we must also have that $a < \infty$ regardless of the theory of motion we are dealing with.
-3
Acceleration depends on velocity per unit time, and velocity on distance per unit time. It is clear that acceleration is infinite for us because space is infinite. For a given time, acceleration is infinite.
JamalS
  • 19,600
-3
The limit to acceleration is c^2/r.
