11
Do the four gamma matrices form a basis for the set of matrices $GL(4,\mathbb{C})$? I was actually trying to evaluate a term like $\gamma^0 M^\dagger \gamma^0$ in a representation independent way, where $M, M^\dagger$ are $4\times 4$ matrices.
SRS
  • 27,790
  • 13
  • 115
  • 365
As previous answers have correctly noted gamma matrices do not forma a basis of $M(4,\mathbb{C})$. Nevertheless you can construct one from them in the following way
  • 1 the identity matrix $\mathbb{1}$
  • 4 matrices $\gamma^\mu$
  • 6 matrices $\sigma^{\mu\nu}=\gamma^{[\mu}\gamma^{\nu]}$
  • 4 matrices $\sigma^{\mu\nu\rho}=\gamma^{[\mu}\gamma^{\nu}\gamma^{\rho]}$
  • 1 matrix $\sigma^{\mu\nu\rho\delta}=\gamma^{[\mu}\gamma^{\nu}\gamma^{\rho}\gamma^{\delta]}=i\epsilon^{\mu\nu\rho\delta}\gamma^5$
these 16 matrices form the basis that we were looking for.
Furthermore they are used to construct the spinor bilinears multiplying by $\bar{\psi}$ on the left and $\psi$ on the right, which transform in the Lorentz indices as follows
  • $\bar{\psi}\psi$ scalar
  • $\bar{\psi}\gamma^\mu\psi$ vector
  • $\bar{\psi}\sigma^{\mu\nu}\psi$ 2nd rank (antisymmetric) tensor
  • $\bar{\psi}\sigma^{\mu\nu\rho}\psi$ pseudovector
  • $\bar{\psi}\gamma^5\psi$ pseudoscalar
the fact that they form a basis of of $M(4,\mathbb{C})$ is very important because these are then the only independent spinor bilinears (i.e $\bar{\psi}M\psi$) that can be constructed, any other can be expressed a linear combination of these. A different issue is if it would make any sense to sum any of these since they are different types of tensors under Lorentz group transformations.
fra_pero
  • 647
jpm
  • 1,528
13
To complement V. Moretti's excellent answer, it's worth emphasizing that the dimension of the four-by-four complex matrices $\mathbb C^{4\times 4}$, when seen as a vector space over $\mathbb C$, is $4\!\times\!4=16$. As such, a set of four matrices (i.e. vectors in $\mathbb C^{4\times 4}$) can never be a basis for it.
It's also worth saying that the general linear group $\text{GL}(4,\mathbb C)\subset\mathbb C^{4\times 4}$, i.e. the four-by-four matrices with nonzero determinant, is not a vector space (for one, it doesn't have a zero), and it is therefore misleading to speak of a basis for it. That said, it is still possible to ask for a minimal set of vectors (i.e. matrices) whose span will contain $\text{GL}(4,\mathbb C)$; this turns out to require a full basis of $\mathbb C^{4\times 4}$ because the matrices you 'skip', $\mathbb C^{4\times 4}\setminus\text{GL}(4,\mathbb C)$, have measure zero, so $\text{GL}(4,\mathbb C)$ is a complex manifold of dimension 16 and requires that many parameters to describe.
Emilio Pisanty
  • 137,480
10
No they do not, due to dimensional reasons, but they are generators of the algebra. That is, $I$ and the products of $\gamma^a$ (products of one, two, three and four matrices) form such a basis.
NOTE ADDED. As Emilio Pisanty correctly remarked (also making some further interesting comments) $GL(4, \mathbb C)$ is not a linear space so questions about bases of it are inappropriate. In fact I implicitly interpreted that $GL(4,\mathbb C)$ as $M(4, \mathbb C)$, the complex algebra of $4\times 4$ complex matrices which, by definition, is also a complex vector space.
