In the renormalization procedure of quantum field theories, say $\lambda \phi^4$ theory for simplicity, we use the physical mass $m$, the physical coupling constant $\lambda$ and the physical field $\phi$ to fix the bare quantities $m_0$, $\lambda_0$ and $\phi_0$.
It is clear that the physical mass $m$ and the physical coupling constant $\lambda$ can be found from experiments (and using the S-matrix). But how does one "measure" the physical field $\phi$?
Edit: I would like to (hopefully) clarify my question. My question is related to field renormalization $\phi_0(x)=\sqrt{Z_\phi}\phi(x)$, and how we decide what value $\phi$ should be. For the physical mass and coupling constant, we can perform experimental measurements to determine their fixed values but we don't seem to do this for the physical field (as far as I understand; I still need to properly interpret JeffDror's answer). Are we basically looking at the divergence of Feynman diagrams and choose $Z_\phi$ such that we can absorb this divergence? If this is true, then this would mean that the "physical" field is a badly chosen word and it would make more sense to call it the "renormalized" field?
Hunter
  • 5,328
To answer this we first need to be clear about why this wavefunction renormalization arises. For simplicity we focus on $\phi^4$ theory. For a free field we have, \begin{equation} \phi ( x ) \left| 0 \right\rangle = \int \frac{ d ^3 p }{ (2\pi)^3 } \frac{1}{ 2 E _{ {\mathbf{p}} } } e ^{ - i {\mathbf{p}} \cdot {\mathbf{x}} } \left| {\mathbf{p}} \right\rangle \end{equation} Apart from the factor of $ \frac{1}{ 2E _{ {\mathbf{p}} }} $ this is just equal to $ \left| {\mathbf{x}} \right\rangle $. Thus we can intereprate $ \phi ( {\mathbf{x}} ) $ acting on the vacuum as a field producing an $ {\mathbf{x}} $ eigenstate.
The equation above can be used to show that \begin{equation} \left\langle 0 \right| \phi ( {\mathbf{x}} ) \left| {\mathbf{p}} \right\rangle = e ^{ i {\mathbf{p}} \cdot {\mathbf{x}} } \end{equation} To continue to interpret $ \phi ( {\mathbf{x}} ) $ as the field that creates $ \left| {\mathbf{x}} \right\rangle $ eigenstates the renormalized field must obey this same relation. Thus we impose the renormalization condition: \begin{equation} \left\langle 0 \right| \phi _r ( 0 ) \left| {\mathbf{p}} \right\rangle = 1 \end{equation}
where $ \phi _r = \sqrt{ Z } \left( \phi - \left\langle \phi \right\rangle \right) $ is the renormalized field. If the wavefunction doesn't change under renormalization then $Z$ is just equal to $1$.
Now $ Z $ is not measurable for the same reason that the bare masses and couplings can't be measured. However, the renormalized field is measured in every process since if the condition above was not set to $1$ then we would be getting an extra factor for each external field line and another for each propagator in every diagram.
For example if we just forgot about the wavefunction renormalization we would get an extra $\sqrt{Z}$ for each external line and an extra $Z$ for each propagator.
JeffDror
  • 9,093
