I read this question at another forum but the thread was already closed. Here's the description: Two observers A and B are both moving at a velocity of 0.9 times the speed of light with respect to a stationary object. So, won't A see B moving at a speed greater than light?
Yashbhatt
  • 1,804
No, A will not see B moving faster than the speed of light due to time dilation. What you are doing is a "Galilean Transformation" which is really just an approximation for objects moving with a velocity much less than the speed of light. The proper equation for velocity transformations in special relativity is:
$$ u'= \frac{u+v}{1+\frac{uv}{c^2}} $$
Where u is B's speed with respect to the stationary observer and v is the speed of A's reference frame which is moving with respect to the stationary observer. A is stationary within its own frame. Plugging in we see that A sees B moving away at $.9945c$ indeed less than the speed of light. Full derivations are available everywhere online like the one mentioned above. Hope this helps.
No, you are imagining the Newtonian addition of velocities. For parallel velocities, the sum is $\frac {0.9+0.9}{1+0.9\cdot 0.9} \approx 0.9945 \lt 1$
