Can a cat be walked with a leash? If so, how can I train a cat to use a leash?
Yes, you can use a leash on a cat; I do it all the time. It's best to start them out at a younger age, but even if they are adult cats, they can still be trained by using a harness and a leash. Try starting out slow, like walking them around the yard with a harness and leash. For awhile, they may just roll over or lay down; just pick them back up and place them in a standing position. I t takes a while to get used to the harness and leash. Cat treats could help to promote a good response.
I would start by getting the cat used to sometimes wearing the harness at home, rewarding cooperation with attention and/or treats as necessary. This will also give you (and the cat) experience in adjusting the harness so that it is tight enough that the cat will not wiggle out of it yet loose enough that the cat is not uncomfortable. Once the cat has accepted the harness (at least reluctantly), walking outside becomes a matter of asking the cat where it wants to go and how quickly; getting the cat to take your direction is a matter of negotiation.
Remember that you are asking the cats to do something that makes no sense to it. Go slow, be patient, try to make the process as low stress as possible for both of you.
- 12,215
- 1
- 28
- 46
