14
Our regularly-trimmed grass outside our gate has been pooped on by another dog. I don't know the dog and I've been trying to determine which dog it was.
I know about dogs being territorial, and that another dog might not poop on our grass once he realizes that our dog is in the house.
Is there any way I can use my dog to mark the grass to notify the other dog that he should not go there? or Is there another way to prevent the other dog from pooping on our grass?
James Jenkins
  • 29,385
  • 40
  • 135
  • 246
Some ideas, since you are unable to identify the other dog:
  1. use a motion-activated sprinkler
    • This will probably scare the dog and owner for the first few times, signaling that you don't want others entering over your grass and doing things
  2. spread a repellant or unpleasant odor
    • ammonia, vinegar, citrus peels or oil, Liquid Fence. You won't need a great amount, and it might kill plants, so apply it to the edge of the grass.
    • If you do buy a dog repellent, follow the instructions because you don't want to cause any harm, just deter the habit.
JoshDM
  • 9,003
  • 51
  • 108
woliveirajr
  • 4,044
  • 31
  • 53
10
Generally, a domesticated dog marking its territory will simply encourage other domesticated dogs to add their own mark. I'm not sure this applies to feces, however, as urine is the primary means of territory marking.
It is possible that getting your dog to mark your yard will prompt the other dog to mark instead of defecating, as most dogs are seemingly indiscriminate about where they'll mark, but quite a few are very discriminating about where they'll defecate (as anyone who has ever suffered outside in freezing rain waiting for their dog to find "just the right spot" will attest!).
However, this will probably be more trouble than its worth. If this isn't an isolated incident, you'll have to have your dog mark the borders of your property regularly for there to be even a chance of it working.
You're better off using other means to try and prevent the other dog from seeing your property as a good location for relieving himself/herself.
The simplest solution is a fence. Even a small ornamental fence is likely to be a sufficient deterrent:
a small ornamental garden fence
Alternately, you can plant something other than grass along the borders of your property. If it the vegetation is sufficiently dense, most dogs will pass it by (then again, we've had a dog trample the one large flower we have in the corner of our yard and deposit a "present" for us right on top of the bent leaves!).
You can also try something based upon a motion sensor, as woliveirajr suggested. There are motion sensor activated ultrasonic pest control devices that supposedly work on dogs, as a possible alternative to a sprinkler that might make you rather unpopular with your neighbors.
Beofett
  • 9,141
  • 53
  • 102
