I use hollow cylinder type container for water for my German shepherd. Every time the container gets dirty with green algae, making my dog not to drink the water. Sometimes even some insects get inside the container. To avoid unhygienic water for my pet, I use the same type of containers always, and clean the dirty container to use it again.
Is there a way to keep the water clean and/or is there a better water container which help?
Mr_Green
  • 183
There's not much to do to keep the water clean outside of changing it regularly. I generally change the water for my cats every morning.
With algae though, if it's growing back within the day, you'll have to take some steps to combat it and try and kill it off as much as possible.
  • It might be as simple as a good hard scrub. You have to get all traces of algae out so it doesn't have anything to grow back with. Unfortunately it really doesn't take much for algae to grow back, and if your water dish is plastic, the plastic is porous enough to keep tiny bits of algae protected
  • Dry it out. If you use another container for a few days, and let the one with algae sit in the sun dry. The dryness and heat should help kill off the algae. This isn't always the case though, as algae quite often goes into a dormant stage.
  • Bleach the container. Bleach should help kill off the algae pretty effectively, but you have to be extra sure that you clean all of the bleach out afterwards. Since it's a container that your dog is drinking out of, the last thing you want is for them to inadvertently drink some bleach water.
To prevent algae growth in the future, making sure the water isn't in any sunlight will be the biggest help. Direct sunlight not only promotes algae growth, but speeds it up. Keeping the water in shade will slow down the growth drastically, and will also help keep the water cooler throughout the day, so it's a win-win there.
You might also want to consider getting a water fountain. You can get some pretty large ones for dogs. What they do is run the water through a carbon filter with a small pump, so not only will the algae have difficulty growing due to the moving water, but that should also discourage most insects that would be attracted to still water. Any insects that would happen to fall in would get caught in the filter, which you would just change every couple of days. I would just make sure to spend the little extra money on a metal fountain, as I had gotten a plastic fountain first, and it was really difficult to keep clean.
Spidercat
  • 15,602
  • 20
  • 74
  • 155
I use a "Lixit Outside Faucet Dog Waterer". It attaches to the outside faucet and they can get clean fresh water anytime. There are other similar products on the market that attach to the faucet as well.
You will have to teach to dog how to use it. Some dogs are easy and others take a little more time to understand what it is.
For indoor use there are also various "indoor dog water fountain" (search google) that you can use inside to keep the water in good shape.
William
  • 266
Ideally, you should use a small container you have at home for your dog to drink out of. This would force you to change or refill the water bowl daily to keep it clean.
KS7X
  • 131
