17
I try to keep my cats' claws trimmed to reduce wear and tear on the furniture (and me :-) ). They also have scratching posts and "pads" that they use regularly, but that's not enough.
My problem is that my vision isn't so great, particularly for close work. Since I need to look longer and more closely at the claw to make sure I'm nowhere near the quick, I can usually only clip three or four nails before the cat squirms away (try again tomorrow). I'd like to improve my efficiency without harming the cats.
I can think of two areas of variability: different ways to hold the cat, and different tools. I currently hold the cat in my lap, with the cat-holding hand over the cat's back and then around to hold the paw (I'm talking about for a front paw here), to try to force the cat between my body and my arm. As for tools, I'm currently using clippers kind of like these, which I can slide over the nail and (once positioned) just squeeze to clip. I've tried small scissors and they seem to be harder to use, but maybe there are better and worse types.
How can I improve on this, so that I can more quickly and reliably clip nails of reluctant cats?
Monica Cellio
  • 8,285
  • 43
  • 83
So, some advice from someone who had to clip the claws of an ornery Tortoise Shell cat as well as a few bunnies that can kick like the blazes...
  1. Don't let the cat tell you when to stop. You need to demonstrate that the clipping is done when you decide that it is done, no sooner.
  2. Use a magnifying glass like the big reading ones on their own pedestal or a magnifying mirror to help guide you.
  3. Have some styptic handy when you do make a bad clip. It happens, don't beat yourself up over it, just help bring it to a stop for your furry friend as fast as possible.
  4. Wrap him/her up in a kitty burrito. Nothing like a towel to bring some of the fuss under control to allow you to get it done. It's especially useful for squirmy cats and bunnies.
Joanne C
  • 20,389
  • 59
  • 104
One thing I've noticed with the cats is that if they have proper scratching surfaces, they'll remove the outer (older) nail surfaces more efficiently, which makes the shape of the claw easier to see (and easier to figure out where to cut).
In the top picture, the cat still has the older, outer cuticle surfaces attached (hasn't scratched them off, or the claw hasn't matured enough yet). In the bottom picture, the outer surfaces have come off, and the shape of the claw is more "moon" shaped.
In the second case, I don't really need to find the quick, because I know it's not in the really skinny part of the claw and I can just tip it off. This makes claw cutting faster (which is easier on the cat).
I don't worry about removing as much claw as I possibly can, instead I try to do quick trims to remove the nail tips every week. Quick trims are less stressful for the cats and also ensure that I get to do a regular "health and wellness" check on our shy cat.
Zaralynda
  • 20,276
  • 15
  • 78
  • 150
I just discovered these clippers for cats' nails, which are supposed to be good for the visually impaired (and anyone, for that matter). That reminded me of this question, so I dug it up to add this information. I haven't tried the product myself, but I have seen two good reviews:
Reviews: http://www.catster.com/lifestyle/my-cat-bubba-gets-a-nail-trim-with-the-zen-clipper http://www.floppycats.com/cat-nail-clippers-for-blind-people.html
Where to buy: http://www.zenclipper.com/buy-now Also available on Amazon
And this may sound weird, but have you tried filing the nails? After all, you only need to blunt the tip slightly. I have no idea how a cat would react to it, but it seems worth a try. I would try filing outward from the paw rather than side to side, as that would be a more natural scratching motion.
If these clippers aren't available to you, consider the advice in [this answer].1
mhwombat
  • 7,702
  • 20
  • 39
