My cat has long whiskers. And she constantly rubs those whiskers on things, like they itch. I read up a bit, and it says that's just their way of declaring ownership with scent glands and such.
Okay, case closed. Except it really seems like she's frustrated with the sides of her face. And if you physically grab her whiskers and just kind of pull on them, she seems more satisfied than annoyed. Like she's happy you're pulling on them, and if you rub the base of the whiskers she seems even happier.
As a human who finds beards being itchy and wanting to shave, I am wondering about her point of view. I've read about trimming whiskers being cruel because cats want to use them for knowing how wide their bodies are etc. But she is clearly having issues with it and I can literally tug on the whiskers and she seems more relieved than annoyed.
Is there any record of overlong whiskers actually annoying a cat? Has a cat ever seemed happier after a whisker trimming? The cat hates nail clippings too, but foregoing that meant she cut up her ear scratching it. Is there something foundational about whiskers where it is not something you should ever worry about because "they are supposed to be as long as they are due to cat science" ?
Cedric H.
  • 7,280
  • 29
  • 76
5 Answers5
16
What do her teeth look like? It seems to me like it's a matter of her gums being irritated. One of my cats had a bad case of gingivitis when I got him, and would aggressively rub his cheeks/teeth on everything he could.
If you cat has gingivitis it could be something as simple as brushing her teeth to get rid of the gum inflammation/irritation. You should be able to lift up your cat's lip to see if there's plaque on the teeth and if the gums look reddish/irritated. Otherwise it might be a good idea to make a quick stop by the vet in case it's something less visible/more serious.
Spidercat
  • 15,602
  • 20
  • 74
  • 155
You should never cut a cat's whiskers. Doing some quick research found these pieces of information:
http://www.todayifoundout.com/index.php/2011/04/what-happens-if-a-cats-whiskers-are-damaged-or-clipped/
http://www.petmd.com/cat/behavior/evr_ct_why_do_cats_have_whiskers
http://www.catster.com/lifestyle/cat-whiskers-7-facts
So whether or not the cat's whiskers are annoying the cat, it's far better than if you cut them. A potential issue like Gingivitis, as Matt said, is far more likely. If this has been going on for a little while, I would definitely recommend taking her into a veterinarian to get her teeth checked.
Waterseas
  • 350
Your cat is scenting things, marking her territory.
Cats have scent glands on the sides of their face, lips, head, and chin (other locations as well). Normal cat behavior is to rub the sides of their face on objects, wall and furniture corners, and people to mark them as their territory or as something friendly or familiar.
Some cats mark more than others. You can experiment with this by plopping something new down in front of your cat, like a coffee mug or something larger. Your cat may sniff it then start rubbing his face on it. Your cat may also want to scent you when you change clothes or after bathing to re-scent you.
I wasn't sure about your cat liking his whiskers manipulated so I just went and gently stroked one of mine's and he began purring, so I guess they like it and see it as grooming.
Beo
  • 4,422
  • 17
  • 17
I don't think your cat is "annoyed" with its whiskers.
It could have mouth problems (tooth issues, jawbone issues) as Matt suggested.
It could have a skin allergy and want to scratch its face.
It could be normal and getting a misinterpretation on its behavior from you.
Whiskers are important for ballance they give feedback on velocity, and position. I would not shave them or do anything to them.
Dan S
  • 4,727
  • 19
She almost certainly has problems with her teeth and needs a vet.
It may not be serious, but immediate action needs to be taken. Action now can save further problems (and costs) later on.
This shows some other symptoms of dental problems in cats: http://www.catchannel.com/magazines/catfancy/february-2012/signs-of-oral-pain.aspx
Most cats will need some dental work in their life, so if she's above 5 years old then this adds even more weight to the argument.
user2143356
  • 101
