-1
I grew up with cats so I'm used to having them.
However my fiance and I decided to get a kitten about 7 months ago (he was about 3 months old then). We had some minor issues when he was younger but he was so small that he couldn't get into much. Since then, he has now destroyed our shower curtain from jumping and hanging on it.
We have many tall windows that he likes to jump onto, but ends up scratching off the paint on our walls (we rent) when he jumps up there.
He's knocked over several decorations either hanging on the wall or just placed somewhere, including glass ones.
He ripped out our curtain rod in the living room by hanging on the curtains and it left a huge hole in the wall from the screws.
He's currently trying to jump on our shelves that aren't very secure or big enough for him, so when he eventually does get up there, I know the shelves will break off the wall also causing huge holes and knocking heavier glass objects off that could hurt someone sitting under them.
He's chewed through an $80 cord and continues to find cords he can chew on.
Anytime I put my food/drinks or really anything on the table or counter, he goes up to it and tries to "clean up" as if in his litter box. This usually results in knives falling off counters, my drinks being spilled, his paws in my food, etc.
We try sleeping with our bedroom door closed so he can have the house, but he ends up scratching the paint and wood off our door and sometimes pulling carpet up.
Once again we are renting which makes this more frustrating. Oh yeah and he tries escaping out of the house any time we open the door. He has gotten out many times but thankfully we are able to catch him before he goes anywhere. He has a cat tower that includes a scratch post, and a scratch post that has hanging toys on it. He shows no interest in either, and doesnt play with his toys.
He is literally destroying our house and everything in it, he seems to always be looking for new things to get into. I understand kitty proofing our house, but at this point it seems we cant have anything on the walls, no decorations, and no curtains.
We do give him love and attention when he wants it, but hes honestly being more of a burden than a blessing.
I'm very frustrated, please help!!
Stig Tore
  • 1,940
  • 13
Entertain your cat more.
Your cat is very young and clearly full of energy. It's taking out its excess energy by doing inappropriate things. If you tire it out more, it'll do these things less. You say it's uninterested in its toys, but that means you need to keep trying.
  • Interactive play with a lure toy or a laser pointer usually works the best.
  • Buy a variety of toys. If the cat doesn't like the toys you have, maybe it's because it doesn't like that type of play. There's catnip, toys that make different noises (bells or crinkling), kicker toys, food puzzle toys, motorized toys, digging toys, and so forth. You might rotate which are available too, to keep them fresh.
  • Figure out games for your cat. For example, many cats like bags and boxes, and they like it if you make the lure toy "hide" or rustle around in a bag.
  • Make windows easy to get to, and free of things it'll knock over and break. Place the cat tree by a window. For most cats windows are the go to for self entertainment.
  • Leash training. If you can manage it, taking the cat out on a little walk often helps to calm it down.
Cat proof your house more.
Part of cat proofing is to get creative. Figure out what your cat likes and doesn't like, and then try to make the thing you don't want it doing unpleasant or impossible, and give it an appealing alternative.
Take the curtains, for example. If possible, replace them with alternatives unsuitable for climbing. Hanging vertical blinds seem the most ideal. Or maybe you could use folding screens you place in the window rather than curtains. I imagine the cat might knock them over on a regular basis, but that's less worrisome. Another option is window tinting/film.
If you really must have curtains, you need to attach them to the wall at actual studs, so if the cat does end up climbing them, they will hold its weight. Then use either cheap curtains that you accept it'll claw up, or see if you can find some curtain that is less suitable for climbing. For example, the thin, sheer kind might be less tempting to the cat. Hopefully also cheap, so if the cat does attempt it anyways, you aren't out a lot of money.
Another suggestion I've seen is breakaway curtains. The idea is to hang your curtain with little threads around the curtain rod, which will immediately break if the cat attempts to climb. The cat will then learn that it's impossible to climb the curtain. You might be able to do a similar sort of thing using velcro instead. This would have the advantage of being easier to put back up if the cat makes an attempt.
The cat may also be climbing the curtains because it wants access to the window. Try giving it another way to get up there that is acceptable, such as place the cat tree right by the window. The cat tree in general was a good thought, but I suspect that you probably did not place it in a good location, which made the cat uninterested in it. Basically anywhere the cat likes to climb up could use a cat tree. The cat will have to use the tree if it's right against the wall, blocking its normal climbing route.
As for chewing the wires, I've seen suggestions to use citrus spray, or even just wrap the wires in soft fabric that's unappealing for chewing. I'd be careful though, as you don't want to make a fire hazard. They also make chew toys for cats. You might try getting some of those as well and see if you can get your cat to chew on those instead.
Kai
  • 16,440
  • 28
  • 59
This seems to be more of a boundary issue rather than needing to figure out the why of it. This answer is a collection of approaches that have worked for me in the past.
Redirecting cats with lightning rods
One of the main differences between cats and dogs is that a dog listens to your commands, but a cat acts based on what's in front of it. You cannot command your cat, but you can steer its behavior.
If your cat has a particular spot they like scratching, try putting the scratching post there. Whenever they go to that location, the scratching post sits there as a lightning rod for the cat's attention. If it likes scratching the scratching post more, then it will scratch the scratching post instead.
The further away you put the scratching post from the scratching spot, the less effective it becomes as a lightning rod.
This, combined with consistent negative feedback about scratching the other things, is usually enough to steer a cat's behavior in the direction you want it to.
Are you not entertained?
Your cat sounds like he's bored. Just like any creature, cats have a finite amount of energy. If you redirect their energy towards (allowed) playing, the naughty playing will lessen (or cease).
Play with your cat. Tire him out. We don't mind our cats running around, but it's a bit annoying when we go to bed. So we play with them just before bed to tire them out, so they're unlikely to want to run around the first few hours after playing with us.
Not every cat likes every toy. Maybe your cat just doesn't like the toys he has.
Buy some varied toys and see which one they're willing to play with by themselves. For example, our cats love the laser, but they are only marginally interested in the automatic laser toy (it doesn't move as interestingly as when I do it). Some toys are a huge hit when I play with them, but a miss when the cat is left to play by itself. Some other toys, however, are a huge hit in terms of the cats playing by themselves.
This is a matter of trial and error.
How to train your cat
There is a lot of ground to cover here, and I can't list all of it. This is a more comprehensive answer of mine that delves into how to train your cat's behavior. Mostly chapter 4 is applicable, but I think the other points are applicable to your case as well.
Buying a plant sprayer can do wonders for training a cat, but you have to use it correctly. If you just use that as the immediate punishment without any verbal warning, you're not teaching your cat anything.
What works a lot better is a series of escalations:
  • State the cat's name.
  • Repeat the cat's name, but louder. Follow up with a clear "no".
  • Take out the sprayer and restate the name/"no".
  • Spray the cat. It doesn't need to be a direct hit, but it needs to come across as intending to hit.
  • If the cat persists, calmly pick them up, bring them to another room, and put them down.
Always start from the top. If the cat does not stop what it's doing, take it to the next level. Whenever the cat yields, you reset the clock and start from the top the next time it happens, even if that is only minutes later.
The goal is to teach the cat a pattern of progression. Initially, it doesn't understand your verbal feedback. But after several experiences, it will start to figure out that these verbal cues are a precursor to a punishment that it really wants to avoid (= the spraying).
Eventually, your cat will learn that if it does not yield when it hears the verbal cue, it's goign to get sprayed. And since it doesn't want to be sprayed, it yields, and your training has succeeded.
Specific feedback
This particular instance seems to be a matter of unintended consequence. I wouldn't particularly fault the cat. Either find a way to shield the wall (we tape cardboard to the wall), teach the cat not to jump up there (more on how to train a cat later) or simply fill the window sill to a point where the cat can't be on it anymore.
This burying behavior stems from cats trying to hide their remains of food because it hides their scent, and cats have a natural instinct to want to hide their presence in an area (which is also why they bury their droppings).
You can't teach the cat that this is wrong because their instinct compels them to do it. At best, you can train them to know that you will get upset with them for doing so.
This sounds like your house is not reasonably catproof. Cats like heights, you can't change that. If your shelves are fragile enough that a cat's weight will literally rip them out of the walls, and you put heavy glass objects on them, that's a recipe for disaster.
You can't reasonably expect your cat to fully tailor itself to what you'll allow and won't allow. Cats don't care about what you want, they care about what they want.
That's not really misbehavior. If you don't want your cat to go out, and it wants to go out, it's up to you to prevent it from doing so.
Closing the door "so he can have the house" sounds like a bit of a misdirection. Even with the door open, they can still be in the house when they want to be. There's an ulterior reason why you're not wanting him in the bedroom.
Your cat clearly wants to be in the bedroom. You clearly don't want it there. Something's got to give. You can try and train your cat to stop trying to get in, but it's not going to be easy or a guaranteed success.
It may be a lot easier to address the issue which is leading you to not want the cat in the bedroom.
Flater
  • 5,666
  • 17
  • 29
