We have a kitten that's about 5 months old and has been diagnosed with FIP (Feline infectious peritonitis) 12 days ago. Since then she's been on treatment with Prednisolone, antibiotics and, for the last 8 days, feline interferon.
She had the fluid in her abdomen drained 8 days ago, and yesterday the veterinarian tried to do it again, but it was too viscous to drain with a syringe, so they said that it couldn't be done.
Has anyone encountered this situation before and knows a solution? I'd really want to have the fluid drain to improve her survival chances and comfort.
Filip
  • 163
The vet would have to make a bigger hole. Usually a 19G butterfly catheter is big enough.
The downside, especially in a kitten that has lost weight and muscle, or does not like to hold still is that when using a larger gauge needle there is a much higher chance that the hole will not close up immediately when finished. Kittens with FIP start to lose muscle diffusely, including abdominal muscles which will not contract back as well. This means that peritoneal fluid could start to leak into the subcutaneous tissues or directly out of the body.
I am sorry to say that with effusive FIP you and your vet need a very frank conversation. Repeated draining of the abdomen does provide short-term relief but the effusion will come back again, if not worse. The prognosis is grave, and the chance of survival even with aggressive treatment is very poor. Euthanasia, as terrible as it is to consider in a young kitten, is often the most humane option.
Best of luck with your treatment for this little kitten.
Harry V.
  • 6,254
  • 18
  • 35
-2
Belly Fluid; Do not have it drained
Draining the abdominal fluid is very risky and can cause your cat to go into shock and pass away. If fluid must be drained, it should be no more than 30%, and only if your cat’s belly becomes so full that eating, bowel movements, or breathing are affected. Chest Fluid can absolutely and must be drained if the kitty’s breathing is labored. This fluid can be drained completely.
agarza
  • 239
