Owners of Labradors are probably familiar with their dogs jumping into everything that contains at least trace amounts of water, murky ponds, muddy puddles, etc.
An answer to a question about a certain sort of amoeba brought up the idea that it should be safest for the dog to only swim in chlorinated water. The answer has since been edited, but I still consider the question to be interesting.
Swimming in chlorinated water is safe for humans, as long as you don't swallow too much. I assume that this is also the case for dogs, but is hard to tell a dog not to swallow any water. Is it safe to let a dog swim in a chlorinated pool?
Baarn
  • 3,026
  • 22
  • 41
This depends on the amount of chlorine in the water. From what I remember from chemistry class, chlorine is used to purify water so a chlorinated water, if there is a chemical-balance is not harmful to your dog. So it is important for the chlorine not to be too much.
However, if there is excess chlorine, your dog will fall sick, if he drinks the water. Even if he doesn't drink water he might get skin irritation and he might have eye problems if the water gets into his eyes.
Make Sure the pH level is between 7.2 and 7.5
