The Tain fairly often specifies specific geographical locations as the settings for its events.
In the final battle of the Tain, Fergus is convinced to turn from the battle and expend his anger on the hills, to spare the men of Ulster.
Thus it was with that sword, which was the sword of Fergus: The sword of Fergus, the sword of Letè from Faery: Whenever he desired to strike with it, it became the size of a rainbow in the air. Thereupon Fergus turned his hand slantwise over the heads of the hosts, so that he smote the three tops of the three hills, so that they are still visible on the moor, and these are the three Maels ('the Balds') of Meath.
The meaning of Mael here seems to be "flat-topped hillock".
This takes place on a plain referred to as "the wide plain of Meath", which I would assume is somewhere around the historic Kingdom of Meath, and generally between Connacht and the Ulaid.
Does this story explain the creation of some known geographic feature?
HDE 226868
  • 7,173
  • 35
  • 81
femtoRgon
  • 9,281
  • 42
  • 83
While it certainly seems to explain the existence of certain hills at the time, there isn't any known landmark to attach this event to.
The battle strongly appears to have taken place in Westmeath, between Athlone and Mullingar, but the hills in question don't seem to be identified.
After attempting collect a bunch of references to known locations of the Tain, I came across a recently written paper including maps explaining, and proposing changes to, the accepted route of the Tain: The Route of Táin Bó Cúailnge Revisited, by Paul Gosling.
Please do go take a look at the map labelled Figure 4 (I have intentionally not reproduced it here, per the Academia.edu licensing terms).
Some locations near the battle can be established clearly and easily:
  • Ath Luane - Modern Athlone, a city in County Westmeath - Where Donn Cuailnge leaves Finnbenach's loins immediately after the battle in question.
  • Ath Firdia - Modern Ardee, a city in County Louth (Complete with local monument) - The location of Cuchullain and Ferdiad's combat.
At Ath Firdia, the Connacht army is making a bee-line back to Cruachan with their prize in tow (harried by Cuchullain along the way, of course). Accepted opinion seems to place the final battle squarely in County Westmeath, somewhere generally between the modern cities of Athlone and Mullingar. The paper fills in the established locations of the camps of Ulster and Connacht:
  • Slemain Midhe (camp of Ulster) - Slanemore Hill
  • Clathra (camp of Connacht) - Clare Hill
And the author gives one location as the most likely location of the battle, as well as giving mention to a second possible location posited in an older resource, supposed supported by local tradition:
  • Garthy - The suggestion by the author
  • Washford Bridge - The suggestion by an earlier researcher.
The two are less than 10 km apart, so pretty close. No statement as to the hills in question though. A speculation can be found here or there, but nothing that seems worth crediting. It's not too hard to see the problem. The author of the above paper describes the surrounding areas as "gently undulating enclosed farmland". Indeed, taking a quick look at a topographic map of the vicinity:
Google topographic map of the areas
Which reveals not much going on. Ushnagh Hill seems to be the most dramatic hill in the area. It's the gentle incline just to the right of the "Killare" label on the map. The hill does appear to have quite a storied history, but I can't find any compelling reason to assume it is one of those mentioned in the story.
femtoRgon
  • 9,281
  • 42
  • 83
