Interest in this epithet of Odin's was renewed when it was casually tossed out in a recent episode of American Gods. *
My question has three parts:
  1. What is the meaning of Grimnir? I found this Old Norse lexical entry for grimmr but welcome more detail.
  2. Is this epithet restricted entirely to the Grímnismál or is it common across the canon?
  3. Is it correct that the use of "grim" in names is a reference to Odin. Thorgrim, Hallgrim, Skallagrim, etc.
* I mention the work that prompted the question because I consider Gaiman an exemplar of modern adaptation of mythological material. It is worth noting that the de facto name for Odin in American Gods is "Mr. Wednesday".
Gallifreyan
  • 243
DukeZhou
  • 14,202
  • 43
  • 106
Grím seems to be a variant of "Grímnir", which means "masked person". A very apt name for Odin. The closest English equivalent is "grimace", while "grim" (similar meaning in old Norse and modern English) seems to be distantly related, and only appears as a byname of Odin, "Asagrim", in a medieval Swedish ballad. (Note the difference between "Grím" and "Grim").
Grímnir and Grím both appear in Grímnismál, they also appear in a portion of Snorri's Edda dealing with the names of Odin. Grímnir also appears in Scaldic poetry as a name for Odin. Wikipedia has a useful list of names of Odin which also gives which sources they appear in.
The other names where "Grím" is a part are likely just names (in particular, "Thorgrim" already has the name of one God as a part, and would not seem to need another one). Note that it's actually "Skalla-Grím", 'bald Grím'.
Sources
For etymology, I consulted Nordiskt runnamnslexikon, a list of names appearing on runestones. It gives "GrímR" -"someone who wears a mask".
I also checked Thorgrim and Hallgrim in the database of Nordiska museet. I only found "Torgrim", but it did not indicate any connection with Odin. "Hall" means "stone".
An old Norse version of Gylfaginning can be found here.
andejons
  • 6,047
  • 24
  • 36
In Norse this particular "grím" refers to a hood, not a mask. In context Odin uses the hood as a disguise (compare the recent TV adaptation of Arrow) and it is from this reference that it is applied more generally to a hood in Norse. Originally however this "grím" appears to have referred to face paint, as worn in battle, then the visor or mask of more elaborate helmets (look up the Sutton Hoo helmet for an example). Note that this "mask/disguise/hood" "grím" has a long vowel (so it rhymes with "cream"), while the unrelated one meaning "severe" has a short vowel. It is this long-vowel "grím" that appears as a name element in wider use (we know this as it appears consistently as Grim- when used a first element, where a short vowel element would [usually] be extended to Grima-), and as such belongs to the wider class of name elements referring to armour and is analogous to "helm". In English the "visor" sense with long vowel fell out of use with the Norman invasion and their new French terms for armour.
