I am a resident of Scotland, and have a credit card issued by my bank in my name only. I recently received a letter stating:
Your credit limit is increasing
We have good news for you. We wanted to thank for being a $BANKNAME customer, and after careful consideration, we've decided to increase your credit limit from $X to $Y on the 05 August 2018.
This amounts to a ~30% increase!
The letter goes on to say that I can decline this increase or request that it takes effect earlier.
What it fails to say is what effect, if any, this increase will have on my credit rating or ability to obtain credit elsewhere. My credit limit is already higher than I intend to use - due to past unrequested increases! - so I am not concerned by accruing additional debt above my current limit.
Other QAs (eg If I increase my credit limit will my credit score go up? or Is there a "catch" on my "increased credit limit"?) suggest that if I was in the US this shouldn't have a negative effect on my credit rating.
What is the situation in the UK? Would an unrequested increase in credit limit effect a credit rating and/or effect one's ability to obtain credit?
bertieb
  • 689
  • 15
Depending on your exact circumstances (other borrowing, other credit facilities, income etc) it's unlikely to have any measurable effect on your credit rating.
Having a credit facility that you aren't using can actually be a positive thing, as long as the amount is not large compared to your income. For example if your income if £10k annually and you have a credit card with a £10k limit other lenders may see that as a bit of a barrier to lending you on top of that.
But even in that case if you aren't using the facility it is better than if you are using it.
Assuming the limit isn't excessive this isn't likely to have any impact on your credit rating and it could be positive.
If you want to know for sure then sign up and get your credit rating for example here:
https://www.clearscore.com
davidjwest
  • 1,502
  • 14
